09-25-2019, 11:02 PM | #1 |
Starter Foot pain
Been working on the A for About 3 days now, Moving it back in forth from the RV pad to the garage. Putting in a Van middle seat That requires a lot of modifying
mainly the frame. Heres the problem, I ware tennis shoes that give your foot no support when trying to start The foot starter rod has a nickel size rod head to push down on. Now I'm paying the price with the pain. I welded a 2" washer on the end which should help. Can the starter system be coverted to a push button system like some of the older cars & what would it take ? Lefthander1930 |
09-25-2019, 11:09 PM | #2 |
Re: Starter Foot pain
It can install a solenoid and button or you could install a device such as the Up-Start. https://www.snydersantiqueauto.com/P...earchByKeyword
There are other solutions also available.
The Master Cylinder Enjoying life at the beach in SoCal... |
09-25-2019, 11:30 PM | #3 |
The spring in your starter switch must be awfully strong!
09-26-2019, 01:28 AM | #4 |
Lefthander30,
Wouldn't it be simpler to wear work shoes, which have more support, instead of tennis shoes? David Serrano |
09-26-2019, 02:12 AM | #5 |
Oh come on David. He's from California. I bet he doesn't wear socks either.
09-26-2019, 03:53 AM | #6 |
09-26-2019, 08:27 AM | #7 |
Flip flops is the State shoe
Lefthander1930 |
09-26-2019, 05:24 AM | #8 |
The two inch washer will solve your problem. You won't even feel the pressure.
09-26-2019, 11:13 AM | #9 |
How about this? https://trisisdesign.com/
09-26-2019, 11:57 PM | #10 | |
I was originally going to wire up a solenoid that would not have cost me much, but I was left with how to modify the original switch and the post on the top of the starter. That would not have been terribly hard, but a pain any way. The already made version made it a heck of a lot easier. |
09-26-2019, 12:14 PM | #11 |
I just had to imagine how many barefoot drivers there were during the depression.
09-26-2019, 01:09 PM | #12 |
"I just had to imagine how many barefoot drivers there were during the depression."
They used the hand crank. Paul in CT |
09-26-2019, 01:42 PM | #13 |
I had the same problem, even though I was wearing boots. I now have a key start in my pickup.
09-26-2019, 08:38 PM | #14 |
Style beats speed any day, and with a lot fewer tickets. |
09-26-2019, 08:44 PM | #15 |
I get the same pain from the accelerator and the footrest if I wear soft soled shoes and I'm on a long drive.
09-27-2019, 12:44 PM | #16 |
I fixed that situation by removing the "button" accelerator and replacing it with a pedal I bought on eBay for a mid '60s Mustang and modified it to fit on the shaft in it's place. It actually looks and feels like it belongs there, as well as solving the problem.
10-01-2019, 08:07 PM | #17 |
Well I got my sparky start today, looked at it for awhile & read direction a few times & started to install. Really very easy once i study the picture provided. It works real well & worth the money.
Lefthander1930 |
10-02-2019, 10:38 AM | #18 |
Had the same problem, our car has firewall insulation inside of the cab. Removed the starter shaft/peddle & cut the 5/8" shaft, added 1"rod. Works better than ever.
Bob |
10-02-2019, 06:23 AM | #19 | |
Ditto on the Sparky-Start ideas mentioned . I had one in mine , worked great . |
09-26-2019, 10:09 PM | #20 |
Here is a mounted "Sparky Start". Always retarded when starting.
