Old 02-02-2020, 03:46 PM   #1
Terranova
Default Flywheel removal.
I come to you fully hat in hand. Is the fly wheel pressure fit to the crank or should I be able to remove it with a couple swift taps of the hammer after I take the bolts out? I may have bitten off just a tad bit to much in this afternoons project. Thank you!
T
Terranova is offline   Reply With Quote
Old 02-02-2020, 03:59 PM   #2
Charlie Stephens
Default Re: Flywheel removal.
I think you are correct but will leave that to others. Be sure to mark the orientation of the flywheel and pressure plate for reassembly.
Charlie Stephens
Old 02-02-2020, 03:59 PM   #3
flatheadmurre
flatheadmurre's Avatar
Youīre on the right track...you just need to motivate it a bit !
Old 02-02-2020, 05:41 PM   #4
Terranova
Mischief managed. Thanks gents.
Old 02-02-2020, 05:55 PM   #5
Mart
Mart's Avatar
I know you've now done it, but I found it easier if the dowel pins are orientated horizontally. It made a very slight difference.
Mart.
Old 02-02-2020, 10:14 PM   #6
Terranova
Mart,
Your videos have been the motivation thatís gotten me out to the garage to get this thing off the tire itís set on for the last 5 years and mounted on the stand.
Thank you!
