10-30-2012, 03:44 AM | #1 |
Radiator coolant level?
Hi guys,
Since you've already been so helpful to me, I have a number of probably quite simple questions I'll ask over the next few weeks! I've tried searching, but maybe using the wrong terms etc. I flushed out the radiator on our 29 Tudor, got lots of rusty gunge out! No serious chunks or solids, but I wanted to add coolant to inhibit corrosion. Anyway; what is a good level to fill the radiator to? I initially filled it until the coolant covered the hole at the weld of the base base of the overflow pipe (does that make sense?). Going up a steep hill it leaked a little out around the cap, and down the overflow. Do I just leave it to sort out it's own level, or hould I keep it topped up to a specific point? Thanks! Allan |
10-30-2012, 03:59 AM | #2 |
Re: Radiator coolant level?
I allways leave 2" of expansion space between top of water level and the overflow pipe,
John Cochran |
10-30-2012, 05:19 AM | #3 |
Just fill it full and let it find it's own level unless it spews out a lot. Down a couple of inches is good but, let it do it on it's own.
10-30-2012, 06:05 AM | #4 |
Coolant should never come out around the cap. Any chance you are using a vented gas cap instead of the correct non-vented radiator cap? Also make sure the gasket is good. I use a cork gasket rather than cardboard in the cap.
10-30-2012, 07:36 AM | #5 |
First I surjust, make sure your cap fits tight and don't leake around it. Then use a 3# pressure valve at the bottom of the overflow pipe. leave the water down an an inch or so. You'll have to build up over 3# pressure before water will come out the overflow pipe. I haven't added water to my 31 with a warmed up B engine for 2 years, and I drive it hard. Walt
10-30-2012, 09:01 AM | #6 |
Berts sells nice leather gaskets for both the gas and radiator caps. They stay in place a lot better than the cork ones, for 28-9 style anyway. Steve |
10-30-2012, 06:10 PM | #7 |
Aha!
I have the cork gasket, but the cap is a vented one! There are 3 slots between the inner part and the outer cover. I did wonder why, but I thought it may be correct, and most of the time the water just goes out the pipe. Maybe someone has swapped them? It's been like it a LOOOOOONG time judging by the rust under the cap. I'll start with sorting that out! Thanks again guys - I really appreciate the answers!
Allan '29 Tudor, Canadian RHD Whangarei, NZ "Duct Tape can't fix stupid, but it can MUFFLE the sound" |
