08-29-2018, 05:20 PM | #21 |
Re: Generator Question
I think they have medicine for contentiousness....
08-30-2018, 09:18 AM | #22 |
Amps is the result of volts being sent through a resistance, so I stand by my volts being sent to the field windings.
08-30-2018, 10:08 AM | #23 | |
It seems 2831A's was banned for standing up to correcting bad info Last edited by 36rtrd; 08-30-2018 at 11:12 AM. |
08-30-2018, 05:58 PM | #24 | |
08-31-2018, 10:35 AM | #25 |
Volts - Amps, I don't care. If you raise the brush that you can see through the opening you lower the output and if you push it down you raise the output. The brush can be moved with the finger but I usually turn off the motor when I stick my finger into anything, then start it again to check the result. You work with what you got. I got all my fingers.
02-22-2020, 11:43 PM | #26 |
warrene |
