Old 05-14-2018, 02:44 PM   #1
Ron Pilger
Ron Pilger's Avatar
Default Aluminum head repair
I am aware of previous posts pertaining to using JB weld and other blends to repair corrosion on heads. Does anyone offer a new, improved repair technique or have a story (good or bad) to offer following many years and many miles. Thanks for your input.
File Type: jpg 51FE8BBB-C005-45BB-82BE-73545818DE55.jpg (33.9 KB, 189 views)
Ron Pilger is offline   Reply With Quote
Old 05-14-2018, 04:02 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Aluminum head repair
Most of what I see doesn't appear to be necessary for sealing purposes, is that correct, just for looks.?
Anything you put on the head where it is not entrapped by the gasket has the possibility of coming off and depositing itself in the cooling system.
Old 05-14-2018, 04:05 PM   #3
petehoovie
petehoovie's Avatar
Be sure to use a good quality composite head gasket with a good 'squish' factor....
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 05-14-2018, 04:28 PM   #4
Angledrive
Angledrive's Avatar
Devcon Epoxy
Angledrive is offline   Reply With Quote
Old 05-14-2018, 05:37 PM   #5
Ron Pilger
Ron Pilger's Avatar
Instinct tells me that no repair should be attempted inside the firing ring. I’ve had very good luck with all types of today’s non copper gaskets, in terms of sealing. I’m curious what Devon or JB looks like after tens years or 10,000 miles of being on the job.
Old 05-14-2018, 05:37 PM   #6
Brian
Brian's Avatar
Ron, run that head as it is.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 05-14-2018, 06:19 PM   #7
petehoovie
petehoovie's Avatar
New original style aluminum heads are being cast by Kearney Pattern Works in San Jose, California.
See > http://www.kearneyfoundry.com/
REPLICA CASTINGS:
Kearney Pattern Works & Foundry manufactures exact duplicate cylinder heads for 1933-1936 Ford V8's, as well as a finned "Hot Rod" version. We manufacture exact duplicate finned cylinder heads for V-12 Lincoln flatheads, as well as a custome 3 carburetor intake manifold. These products are commonly sold to individuals who restore cars and require the very best when entering shows.
Old 05-14-2018, 06:33 PM   #8
35fordtn
35fordtn's Avatar
As a FYI, Kearney is no longer reproducing the Aluminum heads.
35fordtn is offline   Reply With Quote
Old 05-14-2018, 06:35 PM   #9
petehoovie
petehoovie's Avatar
Didn't know that. They might have some left in stock though. I'd call them....
Old 05-14-2018, 06:48 PM   #10
Art Newland
Art Newland's Avatar
I'd try them as-is, but then again I have to do things over a lot. 8^)
"whatever works!"
Art Newland is offline   Reply With Quote
Old 05-14-2018, 07:13 PM   #11
russcc
"If" they actually need to be fixed, welding is the best way to go, unless the quality of the aluminum is suspect. Fordbarners can comment on that based on the year if they are original heads. For example early Eddie Meyer heads are a poor quality aluminum that is not weldable.
russcc is offline   Reply With Quote
Old 05-14-2018, 07:21 PM   #12
Ken/Alabama
Ken/Alabama's Avatar
Devcon or better Belzona. I work in a Papermill and I've seen Belzona used in extreme conditions with 160# steam with no problems.
Ken/Alabama is offline   Reply With Quote
Old 05-14-2018, 10:48 PM   #13
VeryTangled
VeryTangled's Avatar
https://www.belzona.com/en/products/1000/1111.aspx
Says "Excellent adhesion to... aluminum."
Temperature resistance: 93C (200F) immersed, 200C (392F) dry.
The photos are impressive.
Just passing it along.
-Jeff
Sorry I'm such a pill, but why not support the Early Ford V-8 Foundation Museum?
My avatar courtesy of 41ford1. Pic is him and Ol' Ron.
VeryTangled is offline   Reply With Quote
Old 05-15-2018, 12:09 AM   #14
harley
I vote Belzona too. 33 years, 2 paper mills, has made a believer of me. Different formulas, different applications, get the right stuff.
people have more trouble than anybody
harley is offline   Reply With Quote
Old 05-15-2018, 01:39 AM   #15
RalphM
RalphM's Avatar
That head looks usable to me.
RalphM is offline   Reply With Quote
Old 05-15-2018, 08:23 AM   #16
Ron Pilger
Ron Pilger's Avatar
never heard of Belzona until now. Does the stated temp resistance data raise any concern?
Old 05-15-2018, 08:52 AM   #17
whizzernick
whizzernick's Avatar
Belzona very pricery . check e bay
whizzernick is offline   Reply With Quote
Old 05-15-2018, 08:53 AM   #18
51 MERC-CT
51 MERC-CT's Avatar
The only thing that raises a concern to me is the price one would have to pay just to correct a cosmetic situation.
Old 05-15-2018, 09:13 AM   #19
tubman
tubman's Avatar
YIKES! At least $100. I don't care how good it is, that's overpriced.
tubman is online now   Reply With Quote
Old 05-15-2018, 10:36 AM   #20
D. Jones
D. Jones's Avatar
It's a matter of perspective. If you're repairing a head for an old Ford it may seem a bit expensive but, if your working to save a 10 to 50 K injection mould it's trivial.
Just an observation.
D. Jones is offline   Reply With Quote
Thread Tools
Display Modes
