Old 12-08-2019, 11:05 AM   #1
FrankWest
FrankWest's Avatar
Default part id..1932 or 1933/34 v8 ford
are these for 32 v8 or 33/34 v8 water inlet
FrankWest is online now   Reply With Quote
Old 12-08-2019, 11:31 AM   #2
deuce lover
deuce lover's Avatar
Default Re: part id..1932 or 1933/34 v8 ford
'32 V8 bottom water inlets
Old 12-08-2019, 11:36 AM   #3
Bored&Stroked
Bored&Stroked's Avatar
What he says! LOL
Old 12-08-2019, 11:43 AM   #4
FrankWest
FrankWest's Avatar
Does anyone have a picture of the 1933/34 water inlets
Old 12-08-2019, 11:51 AM   #5
DavidG
DavidG's Avatar
They were also used initially on '33 V8s with front cross members that carried over the '32 spacing of the center lines of the motor mount insulators of 12". When that spacing was increased to 17" early in the '33 model year cast iron combined water inlet/motor mount brackets were adopted along with a new front cross member.
DavidG is online now   Reply With Quote
Old 12-08-2019, 12:06 PM   #6
FrankWest
FrankWest's Avatar
Thanks
Old 12-08-2019, 12:37 PM   #7
DavidG
DavidG's Avatar
An early '33 right side motor mount bracket used in concert with the stamped steel water inlet in your photo is shown below along with the early '33 front cross member.
A right side cast iron combined water inlet/mount is shown in the left corner of third photo
Old 12-08-2019, 12:43 PM   #8
deuce lover
Here are the '33.34 ones.Early '33 intlets are like the '32 as David indicated
Old 12-08-2019, 02:01 PM   #9
FrankWest
FrankWest's Avatar
Great info Thanks for all the details.
Old 12-08-2019, 03:09 PM   #10
FrankWest
FrankWest's Avatar
Thanks again
Old 12-10-2019, 07:18 AM   #11
FrankWest
FrankWest's Avatar
will the later one piece inlets/motor mounts block mounting holes compatible with the earlier two piece inlet and motor mount?
Old 12-10-2019, 08:19 AM   #12
DavidG
DavidG's Avatar
The holes for the attachment for the water inlets/motor mounts were unchanged from '32 through '36.
Old 12-10-2019, 08:30 AM   #13
FrankWest
FrankWest's Avatar
Thanks
