Old 10-13-2019, 02:00 PM   #1
westienz
westienz's Avatar
Default 1936 Ford Pickup - Electric Radiator Fan
hey has anyone fitted an electric fan on a 1936 ford pickup radiator and what size and brand have you used ??
westienz is offline   Reply With Quote
Old 10-13-2019, 02:04 PM   #2
ford38v8
ford38v8's Avatar
Default Re: 1936 Ford Pickup - Electric Radiator Fan
It's best to address the reason you're considering an electric fan, as the cons outweigh the pros.
Alan
Old 10-13-2019, 03:02 PM   #3
TJ
TJ's Avatar
If you are 12 volt the best fan is from Cooling Components. Their fans are designed to fit the width of your radiator and come with their own shroud. You will need to run a relay also. They are not cheap, but they do work. They area "puller" type fan.
Old 10-13-2019, 07:12 PM   #4
JSeery
JSeery's Avatar
Also be sure you have the amperage to run the fan, some of them draw more amps than you have available with a generator.
Old 10-13-2019, 07:15 PM   #5
Talkwrench
Talkwrench's Avatar
I run one in my 35 pickup. Its a cheap brand but does pull amps tho'. If I was in the U.S. I'd go a Spal. 16" I use a Davies /Craig digital thermo fan switch [very easy] https://daviescraig.com.au/product/d...h-12v-24v-0444
not really much more to say set it at 185-190 hardly ever comes on for me.
Old 10-13-2019, 10:59 PM   #6
Brian
Brian's Avatar
Westie, Welcome to the barn...nice looking truck in your avatar...we love pictures....along with your intro...regards, Brian [ex-Westie ex Jafa]
