Old 07-04-2019, 02:11 PM   #1
FrankWest
FrankWest's Avatar
Default clutch rod clevis? 1933 model B
I want to adjust the clutch rod clevis, I have more than 2 in play and want to tighten it.
Looking under my car, it seems the clevis is under the brake pedal? Is there another clevis? or is this the one?
FrankWest is offline   Reply With Quote
Old 07-04-2019, 03:13 PM   #2
deuce lover
deuce lover's Avatar
Default Re: clutch rod clevis? 1933 model B
The clevis is connected to the clutch arm of the transmission.That is the only one.Pull the pin then lift it up and unscrew to adjust the play.
deuce lover is offline   Reply With Quote
Old 07-04-2019, 05:05 PM   #3
VeryTangled
VeryTangled's Avatar
Not exactly on topic, but here's a link to a diagram of the system a few years after 33.
http://www.vanpeltsales.com/FH_web/F...35-39_85hp.jpg
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 07-08-2019, 03:17 PM   #4
FrankWest
FrankWest's Avatar
I was able to get the cotter pin off and was able to slip the pin out but now how do I get move the clutch level out of the clevis so that I can shorten it. It there enough play in the clutch lever so that I can slip it off the clevis?
Old 07-08-2019, 06:03 PM   #5
VeryTangled
Can the clevis be pulled upwards to free it from the clutch arm?
-Jeff H
Old 07-08-2019, 06:34 PM   #6
FrankWest
FrankWest's Avatar
I guess I also have to take the other pin off from the clevis shaft.
Old 07-08-2019, 06:47 PM   #7
FrankWest
FrankWest's Avatar
I have 2.5 in play in my clutch pedal, I should shorten the clevis by 1 inch, right?
Old 07-08-2019, 06:59 PM   #8
DavidG
DavidG's Avatar
If you shorten it, you will increase the amount of free travel.
Old 07-08-2019, 09:39 PM   #9
drolston
drolston's Avatar
The radius to the clutch pedal is maybe ten inches. The radius to the clevis pin is maybe 1.5 inches. To take out 1" of excess free play, lengthen the clevis rod by 1" x 1.5" / 10" = .15", ball park. I would unscrew the clevis two full turns and check it. When checking the free play adjustment, be sure to do it with the floor board down tight, as the floor board is what stops the pedal return. You can run out of adjustment if things are badly worn, in which case buy a new clevis and both pins. Available and cheap.
Old 07-09-2019, 02:30 AM   #10
deuce lover
You do not need to remove the other pin.That other pin also has (or should have)the return spring connected to it. Just lift up the clevis and "unscrew it " to take out some of the play.
Old 07-09-2019, 06:57 AM   #11
FrankWest
FrankWest's Avatar
Thanks a million guys. At my age, it is getting tougher to crawl around under the car these days.
Old 07-09-2019, 07:18 AM   #12
deuce lover
I get it.I had a similar problem and my young friend went over the fender to pull the cotter pin and push the clevis pin out to re-adjust it. A little tighter space wise with the V8.Your 4 Cyl will be more forgiving.
Old 07-09-2019, 12:26 PM   #13
FrankWest
FrankWest's Avatar
Does the lever arm move far enough to clear the clevis? I will have to move the lever arm 1-2 inches forward to clear the clevis. Much resistance.
Old 07-09-2019, 12:41 PM   #14
JSeery
JSeery's Avatar
You are not going to move the clutch arm by hand. Think of the leg pressure it requires, and that is with a lot of leverage!
Old 07-09-2019, 12:47 PM   #15
FrankWest
FrankWest's Avatar
well said....any ideas how to move it? is there a factory procedure to slide the clevis off? The original service bullitin just says remove it and adjust.
Old 07-09-2019, 12:56 PM   #16
JSeery
JSeery's Avatar
Should just move up without to much effort.
Old 07-09-2019, 01:00 PM   #17
deuce lover
Just lift it off,simple as that.Then you can move the trans clutch arm by hand until the throw out bearing prevents it from going any further.You might want to have a helper grasp the clutch pedal from inside so its easier to reconnect the clevis after you have taken some of the play out.It might take several attempts to get the adjustment just right.
Old 07-09-2019, 02:20 PM   #18
FrankWest
FrankWest's Avatar
can't get it off. Thinking of taking the floor off, but not sure that would work because the clevis seems to be beyond the basic floor plate. I would most likely have to remove the forward firewall floor plate?
Old 07-09-2019, 02:27 PM   #19
JSeery
JSeery's Avatar
Have you tried a soft bar (like alum or brass) and a hammer? It just sets on there loose, it has to be fairly loose or it could not pivot in use.
Old 07-09-2019, 04:20 PM   #20
FrankWest
FrankWest's Avatar
the clevis moves but the lever arm needs to be pushed forward so that I can slide the clevis off. without the floor/firewall floor plate the clevis would slide right off.
