11-08-2018, 03:50 PM | #1 |
41 windshield install
41 woodie https://41fordwoodie.weebly.com/ |
11-08-2018, 07:56 PM | #2 |
Re: 41 windshield install
Tex, there is a great set of instructions on windshield installation on the Van Pelt Sales web site.
11-09-2018, 12:56 PM | #3 |
Didn't follow the Van Pelt instructions whereby you try to first mount the rubber seal in the window opening. Instead I first put the two windows in the rubber seal and then pushed it into the opening.Getting the two windows into the rubber seal took a lot of sweating to get them in correctly. Pushed the windows/rubber seal combination in place after using dish liquid for lubricant and putting a piece of string in the rubber. Went in magically in a few minutes with the help of pulling the string and some use of the red plastic paddle. I think this way is easier as the rubber seal required a lot of stretching to fit the windows in it. I worried and put it off for several days for nothing.
https://flic.kr/p/P1WkE4
41 woodie https://41fordwoodie.weebly.com/ Last edited by mrtexas; 11-09-2018 at 03:21 PM. |
11-12-2018, 01:32 PM | #4 |
Installing the divider bar. Rubber came with bumps around the holes for the screws. Had to grind them off to fit. Also had to spread the rubber/trim apart with pieces of wood. Window and trim install was very easy.
https://flic.kr/p/2bKr34m
41 woodie https://41fordwoodie.weebly.com/ Last edited by mrtexas; 11-12-2018 at 08:17 PM. |
11-13-2018, 01:59 AM | #5 |
Did the window install from the side of the car and you pulled the rope from the outside?.
11-13-2018, 08:46 AM | #6 |
https://www.fordbarn.com/forum/showt...2185&showall=1 |
11-13-2018, 04:08 PM | #7 |
Yes, both windows assembled into the rubber seal on the ground, the assembly pushed in from inside the car and rope pulled from outside the car.
11-13-2018, 04:09 PM | #8 | |
Assembled on the ground https://flic.kr/p/2bnieHx
11-13-2018, 08:11 PM | #9 |
Once again, the complete instructions, with drawings for installing '40 to '48 Ford windshields are on the Van Pelt web site. Follow them and you can't go wrong.
