Old 08-05-2014, 12:19 AM   #1
Dan Partain
Dan Partain's Avatar
Default Transmission Shaft O-Ring Compressor
I made a quick easy tool today to help me install the transmission shafts with the O-rings, I thought maybe someone else would be interested. It's basically a mini piston ring compressor.
First I took some fine emery cloth to the sharp edges around the holes in the case to get a somewhat beveled edge, but mostly just to cut the sharp edges so they wouldn't shave the O-ring going in. I didn't really want to put a real bevel around the holes.
I took a part from an old computer, one of the block-off plates in the back of a PC to make the tool, it's just the right guage and width for the job. I tried to make it tight where the ends meet, under the screw, so the compressed O-ring wouldn't stick up in that spot.
With a good coat of petroleum jelly, a small hammer on a 1/2" wooden dowel the shafts tapped into the case very smoothly.
Dan Partain is offline   Reply With Quote
Old 08-05-2014, 12:23 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Transmission Shaft O-Ring Compressor
Cool
Old 08-05-2014, 12:38 AM   #3
700rpm
700rpm's Avatar
Pretty darn neat.
Ray Horton, Portland, OR
Old 08-05-2014, 09:15 AM   #4
John
John's Avatar
Good job. I usually take a countersink in my drill press and just break the edge of the transmission casing for the shafts. That makes the O'ring go in even easier.
John is offline   Reply With Quote
Old 08-05-2014, 09:24 AM   #5
C26Pinelake
Very ingenious ! Nice work !
Wayne
C26Pinelake is offline   Reply With Quote
Thread Tools
Display Modes
