Old 01-15-2020, 02:49 PM   #21
Gary WA
Gary WA's Avatar
Default Re: Throttle shaft brass plug for zenith carbs
Originally Posted by Brentwood Bob View Post
Thanks, sent a pm.
Back to you with info
www.whidbeymodelaclub.com
Old 01-16-2020, 04:15 PM   #22
Brentwood Bob
Still looking. Talked with Sacramento vintage, and probably mislead them into thinking part number 85-392 was correct for the 29-31 zenith throttle shaft plug.
The dimension for 85-392 is .47 inches. Need 9/32"
Must be another zenith.
Brentwood Bob is offline   Reply With Quote
Old 01-17-2020, 12:38 PM   #23
katy
katy's Avatar
Is that plug really necessary?
Old 01-17-2020, 02:05 PM   #24
Brian T
Brian T's Avatar
I don't think so, there is seldom any wear on that side of the shaft, I have
2 Zeniths hanging up that do not have them, I believe the plug would only be removed if the bushings have been replaced and reamed, a cost saving change at some time?.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 01-17-2020, 06:09 PM   #25
Brentwood Bob
Necessary is a personal call, since it is on the engine side leaving it alone is an alternative.
Closest similar plug is 1/32 smaller. So now I will see if I can make it work.
