10-11-2016, 12:00 AM | #1 |
Update on my new Stipe shocks
When I first put them on I commented here that they were nicely made but I didn't notice much difference from my old Hoodeyes. But today I went to the Service Bulletins to see how to adjust them for cold weather driving. After making that adjustment, I realized I didn't have them properly adjusted before. And now, Wow! What a difference! They are great! I had assumed they came adjusted from Stipe, but that was not the case.
When all else fails, read the instructions!
10-11-2016, 12:52 AM | #2 |
Re: Update on my new Stipe shocks
When you adjusted them did they adjust harder in both directions or only rebound ie. lever going down?
A bit hard to justify the expense with the exchange rate at the moment. |
10-11-2016, 10:37 AM | #3 |
I only moved the adjustment needle as specified in the Service Bulletins. I didn't test the resistance by hand.
10-11-2016, 10:37 AM | #4 |
I only moved the adjustment needle as specified in the Service Bulletins. I didn't test the resistance by hand. Ford had a special KRW setup for that.
10-11-2016, 11:09 AM | #5 |
mine came with instructions, I am surprised yours did not ! Wayne
10-11-2016, 11:27 AM | #6 |
10-11-2016, 03:48 PM | #7 |
OK. Thanks.
I read a bit of an extract from a book on the web the other day that said Henry insisted on the most expensive shocks available at the time and they cost a dollar each, if I remember right. |
10-11-2016, 04:17 PM | #8 |
10-11-2016, 06:22 PM | #9 |
This is the book.
Interesting about the fuel tank, brakes and shocks. Can't seem to find the bit about the cost shocks tho ... might be there somewhere. https://babel.hathitrust.org/cgi/pt?...iew=1up;seq=37 might take a while for the page to load. |
