06-10-2018, 08:49 PM | #21 |
Re: Right hand drive suggestions
I would go with the exhaust pipe wrap, reflective material on the under side of the floor boards and a fire wall insulator along with a pad under the carpet/mat. Except for the pedal and steering column openings, think how your passenger feels in a left hand car!
06-10-2018, 09:14 PM | #22 | |
Heat wrap helps only a little, heat shield not at all and trying the restrict the size of the openings for the pedals is far from easy - they wobble about as they are pressed so a close fit in the hole means they don’t return to their “home” position. The accelerator, being directly under the steering column only aggravates the whole mess. As I’ve said before, Ford made a mess of their design for the Model A. Seems they didn’t think about what they were doing and how it would work RHD. They had been selling Model Ts RHD for years and clearly intended from the start to do the same with the Model A, yet they didn’t learn from the lessons of the Model T. That said, I still like my As.
