Old 05-02-2018, 05:13 PM   #1
ryanheacox
ryanheacox's Avatar
Default Everyone's Favorite Game: Name That Noise
I'd like to call on everybody's collective expertise to help diagnose a new noise my A is making.
First, here is a link to a video of the noise, https://www.youtube.com/watch?v=SMkSiOYlupI
In the video, I'm coming down a hill. First few seconds, the clutch is in and I have the hand throttle set to about the correct engine speed for 30MPH. Rest of the video, the car is coasting in gear still around 30.
This noise doesn't seem to be coming from the engine but it does seem speed related(faster when the car is moving faster). Sitting still and revving the engine doesn't make the noise.
The only times I've heard have been coasting down hills and as the revs drop between shifting.
Also, seems to be coming from under the floorboard instead of under the hood but it's hard to tell.
Thanks guys.
Old 05-02-2018, 05:37 PM   #2
1955cj5
1955cj5's Avatar
Default Re: Everyone's Favorite Game: Name That Noise
1 vote for the speedometer cable.....has it been lubed recently?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 05-02-2018, 05:46 PM   #3
SeaSlugs
SeaSlugs's Avatar
I second the spedo cable. Easy to test - just unscrew it from the driveshaft and take it for a ride on those same roads.
No vibrations or anything like that when its happening is it? Just purely speed related?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-02-2018, 06:02 PM   #4
kbinde2
kbinde2's Avatar
I just replaced the speedometer cable in my '29, had a noise similar.. although more "whine" in it. Disconnected the cable, no noise.. lubed it and re-installed, still had the noise. A few of the strands had frayed where the cable bends at the firewall, and that provided a sound-box effect to amplify the noise, new cable and my problem solved.!
Just a thought.. Good luck.!
kbinde2 is offline   Reply With Quote
Old 05-02-2018, 08:59 PM   #5
ryanheacox
ryanheacox's Avatar
One thing I failed to mention, pushing in the clutch and letting the engine idle while rolling on that same hill at 30mph makes the noise go away.
Would have never thought of the speedo cable. I'm ashamed to say but it hasn't been lubed since the car has been in my care....which means it has had no attention in at least 6 years and 8,000 miles.
If the weather is nice, I will pull the cable, take the same drive and report back tomorrow.
What lube should be used on the cable?
Old 05-02-2018, 09:25 PM   #6
Anteek29
Anteek29's Avatar
Graphite grease was recommended to me.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 05-03-2018, 07:15 AM   #7
ryanheacox
ryanheacox's Avatar
Graphite makes sense to me. Disconnect both ends of the cable and shoot it in?
Old 05-03-2018, 09:05 AM   #8
1955cj5
1955cj5's Avatar
The way I was shown to lube a speedometer cable was to pull the inner cable out completely, clean it if necessary, then put a quantity of grease in the palm of one hand, and feed the cable through the grease as you feed it into the housing, carrying the grease into the housing and thus lubing the entire cable.
Keep track of which end goes into the speedometer, the two ends may be different.
Nitrile work gloves recommended!
Old 05-03-2018, 09:53 AM   #9
burner31
burner31's Avatar
Cable was my 1st guess also
Keith
Shawnee OK
'31 SW 160-B
Old 05-03-2018, 02:19 PM   #10
ryanheacox
ryanheacox's Avatar
Well... not the speedo cable. Disconnected it, same drive, same noise.
Gonna lube the cable regardless. Any other ideas?
Old 05-03-2018, 02:48 PM   #11
JOHN CT
JOHN CT's Avatar
I guess it’s time to open up the transmission inspection cover. And take a peek.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 05-03-2018, 03:35 PM   #12
1955cj5
1955cj5's Avatar
At first when I listened to your video I thought it might be an exhaust leak, either at the manifold or in the area of the muffler. But it sounded a little metallic....so went with the speedo cable...
I would do as John suggests and take the inspection cover off the clutch housing and see what you find....maybe a loose finger on the pressure plate?
Old 05-03-2018, 04:02 PM   #13
ryanheacox
ryanheacox's Avatar
Pulled the lower floorboard and went for a little drive. Can't see anything blatantly obvious and still no closer to pinpointing the noise.
What are the odds it's something serious?
Old 05-03-2018, 04:03 PM   #14
ryanheacox
ryanheacox's Avatar
Gonna pull the cover now.
Old 05-03-2018, 07:49 PM   #15
ryanheacox
ryanheacox's Avatar
I think you may be on to something. I rotated the engine around and pushed on all of the pressure plate fingers(the exposed end) with a screwdriver and none budged but one, I was able to push it maybe 1/16". It also looked like the adjusting nut was backed off further than the rest.
What's the correct way to adjust them and can it be done in the car?
Old 05-03-2018, 08:09 PM   #16
J Franklin
J Franklin's Avatar
Measure the lever height of the others and make the odd one the same, it can be done from the front seat.
Old 05-04-2018, 08:12 AM   #17
ryanheacox
ryanheacox's Avatar
Good, thats all I was hoping I'd have to do. Thanks! Hopefully I'll have some free time this afternoon.
Old 05-05-2018, 08:38 AM   #18
ryanheacox
ryanheacox's Avatar
So I tightened up the one nut to match the rest of them, haven't test driven it yet.
New development though. Could it be the timing gear?
https://www.youtube.com/watch?v=rldiSdcjPIM
That noise has been there for a while but it was always much, much quieter.
Old 05-24-2018, 10:31 AM   #19
ryanheacox
ryanheacox's Avatar
Well, it makes noise pretty much all the time now except for when it's under a good load or idling. Always goes away quickly by pushing in the clutch while rolling. Seems to be getting worse but I just don't know how serious it could be.
The rods are in pretty rough shape but were all within clearance spec when I checked last year.
Drove it to work and just went out and started it to see if I could get it to make the noise without moving and it sounded perfect. I'm really stumped.
It seems to be coming from the bell housing area but it's hard to tell.
Old 05-24-2018, 11:12 AM   #20
Big hammer
Thanks guys.
Two long of starter bolts touching the flywheel? when the clutch is pushed in the flywheel moves away.
get a bigger hammer tap done
