Old 03-13-2019, 01:56 PM   #21
scicala
scicala's Avatar
Default Re: How to tell difference between 272ci and 292 ci
The engine that had a 7.6:1 comp ratio was a 272 two barrel engine. The police interceptors in '55 had 4 barrel carbs whether they were 272's or 292's.
My documentation is everything I have ever read or seen in my life. The manual was printed earlier than the 272 4 barrel was decided to be in production, since it isn't in the shop manual.
Sal
Old 03-13-2019, 02:00 PM   #22
scicala
scicala's Avatar
"The ECJ required premium fuel. The INTERCEPTOR did not as most government fleets used their fuel stocks for all vehicles (gasoline). The 7.6:1 CR only required regular gasoline."
"There are differences between POLICE and HP engines."
Documentation ? What is an HP engine in '55 ?
Sal
Old 03-13-2019, 02:29 PM   #23
Oldmics
In the BIG Master Holley book they list a 4bbl carb for the 55 Ford Fairlane and Wagons with Power Pack kit.
Curiously it does not mention what sized engine this carb is attached to as it usually does with there specifications.
A little fuel for the campfire !
Oldmics
Oldmics is offline   Reply With Quote
Old 03-13-2019, 04:52 PM   #24
KULTULZ
KULTULZ's Avatar
Post Re: How to tell difference between 272ci and 292 ci
Oldmics
The 1955 'POWER PACK' was the 272 4V SPECIAL 188HP.
I had a bulletin describing the engine but can't find it. Do you have a copy?
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 03-13-2019, 05:12 PM   #25
Oldmics
As requested
Old 03-13-2019, 05:29 PM   #26
KULTULZ
KULTULZ's Avatar
Sal
The documentation is in the shop manual. The ECJ Engines are the HP (or what FORD considered HP at that time period) engines for the 1955 model run.
A POLICE PACKAGE could include any available engine. It depended on the departments needs and budget.
- WHY IS IT ... -
Old 03-13-2019, 05:36 PM   #27
KULTULZ
KULTULZ's Avatar
Thumbs up Re: How to tell difference between 272ci and 292 ci
Originally Posted by oldmics View Post
as requested
thank you!
- WHY IS IT ... -
Old 03-13-2019, 05:49 PM   #28
5851a
http://www.oldcarbrochures.org/North...cy_Vehicles-08. On page 8 it shows the engines, but this is just a brochure. Hard to tell what actually ended up at the dealer.
5851a is offline   Reply With Quote
Old 03-14-2019, 03:55 AM   #29
KULTULZ
KULTULZ's Avatar
Here is a CROP of the ENGINE SECTION of the above page -
THANX MIKE!
- WHY IS IT ... -
Old 03-14-2019, 05:49 PM   #30
KULTULZ
KULTULZ's Avatar
Cool Re: How to tell difference between 272ci and 292 ci
Originally Posted by kultulz View Post
...a police package could include any available engine. It depended on the departments needs and budget.
TO WIT-
The Short Arm of The Law
- WHY IS IT ... -
Old 03-14-2019, 07:08 PM   #31
scicala
scicala's Avatar
I now realize the '55 Interceptor was the same as the '55 Mercury base engine (188 HP). And it did have a 7.6 to 1 comp ratio. Forgot about that variation of the 292.
I apologize for insisting otherwise in earlier posts.
Sal
Old 03-15-2019, 01:33 AM   #32
KULTULZ
KULTULZ's Avatar
Sal
Sal, you needn't apologize for anything. This was a discussion and with these we find out what the facts are (were) and throw-out a lot of old wives tales.
- WHY IS IT ... -
Old 03-22-2019, 10:42 AM   #33
grumppyoldman
grumppyoldman's Avatar
I read somewhere that the 292 and the 312 blocks were the same and the 272 was different. So maybe the 272 can't be bored out to 292, because of wall thickness. I am going to see the car on the 29th, the owner swears it's a 292, we'll see. Al
grumppyoldman is offline   Reply With Quote
Old 03-22-2019, 01:26 PM   #34
KULTULZ
KULTULZ's Avatar
The 272CI block can be machined to 292CI block specifications (cyl bore).
- WHY IS IT ... -
Old 03-22-2019, 05:27 PM   #35
dmsfrr
dmsfrr's Avatar
..............Bore....Stroke
272 cu.in. 3.62 X 3.30"
292 cu.in. 3.75 X 3.30"
from this link...
http://www.ford-y-block.com/dimensions.htm
dmsfrr is offline   Reply With Quote
Old 03-23-2019, 06:31 PM   #36
grumppyoldman
Ok enough all ready, I'm going by the casting no's on the block. If it shows a 272 no I won't buy it. He said-she said. Al
Thread Tools
Display Modes
