07-20-2014, 08:11 PM | #1 |
Head Question
I purchased an original head from a friend to put on my car. I noticed the head, on the top, has a small Ford script stamped in it. I've never seen that before. Any ideas on this? Was it normal? Is this a rare head or anything? Thanks!
1929 Model A Ford Coupe |
07-20-2014, 08:58 PM | #2 |
Re: Head Question
07-20-2014, 09:02 PM | #3 |
Re: Head Question
07-20-2014, 09:11 PM | #4 |
Re: Head Question
07-20-2014, 09:37 PM | #5 |
Re: Head Question
I've read that the early heads had Ford script and slightly higher compression but have never found one. I've had, probably still do have model A heads with Ford script but they have 1940s dates on them and normal model A combustion chambers.
07-21-2014, 12:11 AM | #6 |
Re: Head Question
07-21-2014, 06:05 AM | #7 |
Re: Head Question
Dave, neither of these heads are the earliest sample. I sold one to Charles Reese on here that was of the earliest type. This head had a raised round boss for the lock bolt and used a special bolt. I don't remember it having a script. Maybe Charles can post some pics of it.
http://www.model-a-ford-4bangers.com/ Last edited by James Rogers; 07-21-2014 at 06:19 AM. |
07-21-2014, 08:56 AM | #8 |
Re: Head Question
Neither of those are even 1928 style heads.. The script one was made Ford, but well into the 1930s..
07-21-2014, 02:52 PM | #9 |
Re: Head Question
True. The early heads lacked the oblong hole in the water jacket which was later added to improve coolant flow. They were also reported to have a slightly higher compression ratio than later heads.
07-21-2014, 10:22 PM | #10 |
Re: Head Question
Also, most diamond block heads had the Ford script. Look under the water pump area and see if there is a small diamond. Supposedly diamond heads are stronger that original heads.
Brian SATX |
07-22-2014, 12:32 AM | #11 |
Re: Head Question
I have an early one with no oblong water passage in the center and there is no Ford
script on it. |
07-22-2014, 01:06 AM | #12 |
Re: Head Question
I took another look at the script head and found a date 10-30-47 embossed on the water pump area. so everybody's right about that but there's still a difference in the water jacket cross sections, The oblong holes are different and the two holes on the top in the pictures are larger. I have seen this in other non script heads and assumed it was a running improvement but I'll defer to the pros.
07-22-2014, 04:39 AM | #13 |
Re: Head Question
