Old 07-11-2018, 09:48 AM   #1
pgerhardt
pgerhardt's Avatar
Default "Gener-Nator"?
Currently I am running a Powermaster alternator/generator look-a-like in my 29 tudor. However it is not a complete solution. The Powermaster is 1 & 1/4 inches larger in diameter than the model A generator. I think they just shipped their V-8 unit with the brackets needed to install on a model A. On a V-8 size is not an issue since the generator is on top of the engine with nothing else around it (Picture 1), but on the model A the larger size means that the Powermaster unit rubs up against the block. I have a piece of rubber keeping them separate (picture 2) . However it is not a good solution.
I am in touch with Don Allen who can build a "Generator-Nator" (an alternator in an actual model A generator case). This would be a true solution, but these are NOT cheap at $1K. This was expected as this is not a manufactured product, but appears to be custom built by Don for each order.
I am at the age, and stage of life, where I can afford one. However I don't want to throw away $1K either. has anyone out their run one of Don's "Gener-Nators", and how it it perform for you?
Thanks in advance for your response.
File Type: jpg Flathead_Engine_completeV8-60_color.jpg (23.6 KB, 71 views)
pgerhardt is offline   Reply With Quote
Old 07-11-2018, 10:02 AM   #2
GerryAllen
Default Re: "Gener-Nator"?
Please I am not being cheeky. My suggestion is buy a standard alternator and be happy that you could afford better if you wanted. I looked at the same option you bought and thought how often am I going to open the hood to admire the alternator casing
JMHO
Gerry Allen Birch Bay WA
GerryAllen is offline   Reply With Quote
Old 07-11-2018, 10:05 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
1000 dollars, That is a lot of gas for driving. What are your expectations for the unit?
That is the top question to be answered.
The generator can be restored with a regulator for far far less than a grand. This will give you a unit that will provide more years of service then you have on this earth.
But that I just me, what do you want?
Old 07-11-2018, 10:08 AM   #4
Jason in TX
Jason in TX's Avatar
There is someone in the Denver CO area doing these in original V8 cases. The V8 ones I've seen are VERY nice. I've sent him a message. He may reach out to you if he is available or can help.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 07-11-2018, 10:41 AM   #5
Y-Blockhead
Y-Blockhead's Avatar
I used a longer belt, not a problem...
Are your wires connected properly? My wires connect to the lug on the front side of the "Fake cutout" per instructions.
Y-Blockhead
'30 Briggs Town Sedan
'55 Ford Ranchwagon
_________________________________
And once again that is just my 1¢ worth.
https://www.youtube.com/watch?v=aH2TvmjxIFM
Old 07-11-2018, 10:53 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
I run a completely stock original model A generator on 12 volts with good service . I run a Fun Projects can style 12 volt voltage regulator that takes the place of the cut out . Fun Projects also offers a 6 volt and 8 volt version of the can style voltage regulator . If high amps for lots off accessories is required , an alternator would be a better choice .
Old 07-11-2018, 11:34 AM   #7
Badpuppy
According to Jim Schild's "Restorer's Model A Shop Manual" the powerhouse was used through mid-1929. Apparently Y-Blockhead's solution is correct. Keep what you have and put your money into a new fan belt.
Good info - http://www.biedlers-belts.com/single...r-ii-belt.html
Old 07-11-2018, 01:55 PM   #8
1931 flamingo
1931 flamingo's Avatar
What if you use a longer fan belt and redo the tension bracket??
Paul in CT
Old 07-11-2018, 02:43 PM   #9
antiquepa
antiquepa's Avatar
I have one on my 31 roadster, my problem was that it sat on top radiator hose so i got a little shorter belt, so far so good. sounds like you'll need a little longer belt. I do like my gen/alt. and it looks like it belongs.
antiquepa is offline   Reply With Quote
Old 07-11-2018, 02:45 PM   #10
antiquepa
antiquepa's Avatar
[it sat on top of bottom radiator hose]
Old 07-11-2018, 02:53 PM   #11
pgerhardt
pgerhardt's Avatar
Can you tell me the part number for the belt that worked for you? When I used a longer belt (the stock one) the Powermaster pulley rubbed against the lower radiator hose.
On the model A generator the power output terminal is near the front of the generator. the power passes through the cutout and your wires are connected toward the back of the generator (picture 1). To get a similar look I mounted a nice ford script cutout backwards on the Powermaster. (picture 2) No current passes through the cutout. It comes out of the power output terminal (near the rear of the Powermaster) and to my wiring. Most never realize it is backwards!
File Type: jpg Screen Shot 2018-07-11 at 3.39.37 PM.jpg (50.2 KB, 34 views)
Old 07-11-2018, 03:29 PM   #12
Y-Blockhead
Hmmm, we don't have many options. I'm running a Gates B41 (44") and it works fine. The stock belt is a Gates B40 (43") and that was too short for mine.
About rubbing on the hose, I don't know if there is a difference between a '29 (yours0 and '30 (mine).
Y-Blockhead
'55 Ford Ranchwagon
Old 07-11-2018, 06:46 PM   #13
jrelliott
jrelliott's Avatar
I am running an original Power House (3 brush) at 12 Volts. Do not have a voltage regulator on it as yet, but in the process of designing one that will go inside the case. Puts out about 10Amps on the lowest brush setting. The generator neither hits the block or the bottom radiator hose. Think this generator is larger in diameter than the generator/alternator you are looking at. Get the longer 44 inch belt as other have suggested.
Old 07-12-2018, 04:37 PM   #14
JBill
The belt here looks way out of line, but of course it might just be the angle from which the photo was taken.
JBill is offline   Reply With Quote
Old 07-13-2018, 11:46 AM   #15
Badpuppy
Set the generator where you like it and measure the length of a string run around the pulleys. I'd say a B41 would do it.
Old 07-13-2018, 05:47 PM   #16
AL in NY
AL in NY's Avatar
Russ Evans in Simi Valley, California makes an alternator that looks exactly like the Model A generator, cutout included. It's a 45 amp, 6 volt, positive ground unit that will pass fine point judging. It cost about $385.00 (one year ago). Russ stands 100% behind his alternators and will replace any defective units without question. He is a Model A guy and will build the unit for your car, just supply him with your month/year build date and he will make up one exactly as needed for your car. He doesn't have a web site or email, but he can be reached by phone at (805) 583-4221. He also makes a 12 volt, negative ground unit. I bought mine from Russ because I felt better about giving my money to him verse a big corporation.
New number for Russ Evans: (805) 428-2564
AL in NY
AL in NY is offline   Reply With Quote
Old 07-14-2018, 06:36 AM   #17
pgerhardt
pgerhardt's Avatar
Thanks for the info!
Old 07-14-2018, 12:12 PM   #18
Badpuppy
The Powermaster is probably correct for your '29. I don't believe they were used on V-8s.
