11-24-2019, 12:00 PM | #1 |
Help identifying these '40-style rear hubs
Hi Folks:
I'm trying to figure out what I have here. I purchased some '40 style rear hubs. The ones with the larger diameter open was bare. The other one had the bearing and grease seal still in there, so I didn't realize the difference under I removed those parts. What do I have? It appears the one with smaller diameter has those parts pressed in, but I'm not sure. Any help would be appreciated. Thanks, Tim Last edited by Tim Ayers; 11-24-2019 at 12:42 PM. |
11-24-2019, 12:31 PM | #2 |
Re: Help identifying these '40-style rear hubs
post a few pictures of the other side
11-24-2019, 12:42 PM | #3 |
11-24-2019, 02:08 PM | #4 |
Ford used two sized bearings. Thay all fit the axle stubs but must be used with the corresponding hubs. 32-36 was bigger at 3.19. 36-48 at 2.84
11-24-2019, 04:10 PM | #5 |
11-24-2019, 04:50 PM | #6 |
11-25-2019, 08:53 AM | #7 |
Question Andy: Are the drum mounting face offsets the same? Given the different brake shoe widths - are the 40's different than the 32s (for instance)?
11-25-2019, 03:25 PM | #8 |
But, aren't the hub and drum all one piece up through 37 or maybe even 39 (except for those wide-five ones that were made with a big hub and narrow drum, which we are sure isn't the kind pictured)? So these would have to be made for a 40 or later?
Thread Tools | |
Display Modes | |
