06-18-2018, 01:38 AM | #1 |
Which rear end parts are interchangeable between 1932 rear and 1934 rear ??
I’m in the process of building a Columbia rear end . I have a 1934 rear that will be mated to the Columbia . I was curious how similar the 1932 and 1934 rear are. Does the ring and pinion from 1932 rear work inside a 1934 rear? Or any other items ?
06-18-2018, 02:27 AM | #2 |
Re: Which rear end parts are interchangeable between 1932 rear and 1934 rear ??
Only the late '32 is similar except for the position of the radius rod brackets to the '33-34.The '32 with the round torque tube flange uses the same R&P as the Model A.The axle tube end bells might interchange.The torque tube and driveshaft of the late '32 compared to the '33-34 V8 is shorter by 8 9/16".
06-18-2018, 10:19 AM | #3 |
Sheldon,
Some 'real' late '32 rear axles with bearings on both sides of the pinion gear had straight rear axle radius rods and the matching axle housings like '33'34s. I have a late standard Fordor with the late frame, late transmission case, steel oil pan, and late rear axle with straight radius rods. |
06-18-2018, 11:23 AM | #4 | |
I should have mentioned that.I know that they are straight and in 33 - angled.Never seen a late 32 rear with the angled brackets. |
06-18-2018, 08:29 PM | #5 |
Just in case you don't know . . . if you have a later Columbia, it is probably designed for the wider center section - not the 34 center section. You'll need to run a spacer ring to bring the center section up to the later width. There are a lot of little nuances to know - is best to work with one of the Columbia Rear experts.
06-18-2018, 08:50 PM | #6 | |
Now I’m thinking I may just bite the bullet and pull the car off the frame and do a full ground up resto on it |
06-19-2018, 07:52 AM | #7 |
Here is a suggestion.Change your gears out to 3.54.Joe in Temple City can do that for you.Reinstall it and drive your car.You can have the car on the road in as little as 2 wks.In the meantime have a Columbia set up done for your car,if that is what you want in the end. You can then install the Columbia and sell your 3.54 rear with no problem.
