12-11-2017, 08:06 PM | #21 |
Re: 34 Side Glass Install- HELP!
OK, hadn't seen that style of channel, but then there is a lot I haven't seen!! So you solved the issue with getting the glass in?
12-11-2017, 09:46 PM | #22 |
12-12-2017, 08:18 PM | #23 |
Please forgive me for not properly introducing myself first but United Pacific (the steel deuce 5W people) make nice window retaining channels for '34 Fords.
12-12-2017, 08:40 PM | #24 |
MAD, do you happen to have a link for that part? All I can find on their site is 32 5w parts.
12-12-2017, 09:31 PM | #25 |
They are here, Classic car division.
http://www.uapac.com/antique/ http://www.uapac.com/antique/1934-fo...s-channel.html Maybe they can be altered for 5 window and 4 door. |
12-13-2017, 03:10 AM | #26 |
12-13-2017, 06:14 AM | #27 |
There's some measurements in the restorers book
12-13-2017, 03:03 PM | #28 |
Karl The difference between 3window 4door
Is the glass is longer on the 3 window so the channel is longer most channels need trimming so it has less cut of the end at the rear about 2" longer .The ones I have checked from the roller gap forward all channels are the same ,not sure about Tudor but I think the same would apply . |
12-17-2017, 11:07 PM | #29 |
Finally Success
This is how I did it step by step 1. Remove rail and then remove regulator 2 Install glass and push right up Hold in pace with duct tape 3. Place regularator inside door with arms down 4. Install rail on regulator arms 5. Install regulator in door 6. Move rail up and down by winding regulator through full range Slide rail back or forward to insure regulator arms don't pop of rail ends ( A little silicone helps ) 7. Fill channel with urethrane . Don't use glass setting tape as nothing can move with this and some movement is required 8. Wind the rail up and guide onto base of glass 9. Wind up fully 10.Clean excess ooze off 11. Leave for 24 hours |
