Old 07-19-2018, 10:52 AM   #1
Houdini
Houdini's Avatar
Default Where to store your extra wheels
Have an extra wheel or two and wondering where you might store them, yet make them functional in the meantime. How about a stool.
I decided to make a stool for my shop with the stamped steel tractor seat I got at a flea market, and came up with using my very cracked extra 19" wheel as part of the base, to add weight as well as novelty.
The stool is about 24 inches high. I cut a circular piece of plywood for the base and attached 5 caster wheels, so it wouldn't be tippy. Then bolted down a 1.5 inch pipe flange to screw the pipe post into. The top of the posted is a welded on piece of flat steel to attach the seat to. The plywood was cut so it fit into the outer edge of the rim. To save buying fine thread bolts for the wheel, I tapped old lug nuts to coarse thread, as that was easy to do and allowed me to use standard coarse thread 1/2 bolts. Finally got around to painting the wheel bright yellow the other day and to my surprise, there are even more cracks and bad welds than I originally thought. Looks like even a whole section between two spokes around the hub was all cracked out. Makes me wonder (and worry) how a wheel could have gotten so badly cracked. And to think this was on my car once(prior to me owning it).
I need to still find something to put around part of the upper rim, as to use the stool comfortably, one would put their feet on the edge of the rim. Maybe slit a piece of heavy hose and put that on?
Anyone else find ways to use their old wheels.
Houdini is offline   Reply With Quote
Old 07-19-2018, 11:15 AM   #2
Benson
Default Re: Where to store your extra wheels
One way they get cracked is when someone runs late "B" wheels on an early AR Drum/Hub and vise versa.
Benson is offline   Reply With Quote
Old 07-19-2018, 12:03 PM   #3
saintjoelarry
I love it. Creative and functional.
Way to go!
saintjoelarry is offline   Reply With Quote
Old 07-19-2018, 04:27 PM   #4
30 Mike
wow ! that's really cool!
30 Mike is offline   Reply With Quote
Old 07-19-2018, 04:30 PM   #5
Big hammer
Nice! But now there not spares :-)
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 07-20-2018, 01:02 AM   #6
noboD
I keep a junk wheel and tire leaning against a post at the end of my driveway. Every once in a while someone steals it. The next day there's a new one there, messes with their head!!
noboD is offline   Reply With Quote
Old 07-20-2018, 07:11 AM   #7
rocket1
Cut a wheel in half and mount it to the house or barn,use it to coil a air hose or garden hose around.
rocket1 is offline   Reply With Quote
Old 07-20-2018, 10:21 AM   #8
Houdini
Houdini's Avatar
Rocket1, Like the idea of using an old wheel as a hose holder. Could even use it without cutting it. Thanks for the idea.
NoboD, you must have a lot of junk wheels to keep replacing them, when they disappear.
Old 07-20-2018, 04:55 PM   #9
Vin-tin
Vin-tin's Avatar
This is what I did with an old wheel I had sitting around. Thought it might please the wife and maybe help her to like old cars a little bit. I was wrong.
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 07-20-2018, 06:23 PM   #10
28
Planning a clock. Just haven't gotten to it because I like getting projects faster than I can finish them.
28 is offline   Reply With Quote
Old 07-23-2018, 12:38 PM   #11
amodel25
amodel25's Avatar
I had a couple of 19" wheels that were too cracked to repair so I used them to make a mailbox post in 1982. I had a post on the bottom with a 12" x 12" plate on the bottom of the post. Had the thing in the ground 3 feet with two bags of concrete. Nobody was going to knock this one over. Sold the house (and mailbox post) in 1994. I f9nally decided to drive by and check out the old house last year. Lo and behold there was my mailbox post standing proudly, still in service. I've had thoughts about stopping and offering to buy it but I'd never get it out of the ground........
amodel25 is offline   Reply With Quote
Thread Tools
Display Modes
