12-12-2012, 04:40 PM | #1 |
Lubing window regulator and track
What lube do you guys use for this? My new glass should be cut by the end of the week and my regulators are dry and somewhat stiff. Do you just use a thin coat of regular grease?
1929 Model A Barn find. California car, just a few more parts to find. Interior, steering box (rebuild), and I am sure much more! |
12-12-2012, 05:21 PM | #2 |
Re: Lubing window regulator and track
On the regulators I've always found that white lithium grease works well.
12-12-2012, 05:30 PM | #3 |
I just use regular lube grease.
12-12-2012, 05:44 PM | #4 |
If you can find a spray graphite, then coat it in white lube/spray white lube, you'll be happy and grease does tend to get hard if you don't work it all of the time.
12-12-2012, 07:46 PM | #5 |
Great, I was worried about regular grease 'melting' and falling into the door then seeping out through the seam on a hot day over time and greasings.
12-12-2012, 09:29 PM | #6 |
12-12-2012, 10:12 PM | #7 |
Lubri Plate
Oklahoma City Model A Restorers Group. |
