03-24-2018, 02:35 PM | #1 |
rear brake drum question
I'm swapping rear brakes from one car to another.
Old ones are worn, new ones were rebuilt recently and come with cast drums. I've swapped the backing plate as well. Is there something I'm missing or doing incorrectly? I can't seem to get the drum back on and cannot tell if it's hitting somewhere. I just removed them from the other car, so I know they fit before. Any thoughts? |
03-24-2018, 02:43 PM | #2 | |
Re: rear brake drum question
Did you disassemble the brakes at all or just swap loaded backing plates? Regards Bill |
03-24-2018, 02:46 PM | #3 |
Have you backed off the adjusting wedge as far as it will go? I note you have beveled the main brake shoes, which is good, but I usually take that bevel back about a half inch so there’s no edge to catch on.
03-24-2018, 03:34 PM | #4 |
If you've connected the brake rods, you might try disconnecting them. The adjustment might be very different now that they're fastened to different brakes, especially since you've said the previous ones were quite worn. Just a thought.
03-24-2018, 05:12 PM | #5 | |||
Guess do some measuring and check back |
03-24-2018, 05:23 PM | #6 |
When I did my brakes last fall, I ordered new e-brake linings that I had to rivet on myself. The pre-drilled holes did not fit the band exactly and some puckers resulted. The e-brake band and lining have very little clearance. I had to get out my multi-tool and do a bunch of sanding on the pucker to round it back out. You can easily check if the problem is the e-brake or not by taking the e-brake lining off entirely and try putting the brake drum back on without the e-brake. That way, you can narrow the issue down. Also, make sure that the brake sets you brought over from the other car match to the same side as far as the drum is concerned. |
03-24-2018, 05:58 PM | #7 |
Isn’t that back plate on upside down?
03-24-2018, 07:17 PM | #8 |
I took it apart, put it back together and the drum goes on.
I’m embarrassed to say it, but I think I had the shoes reversed. Only thing I can think of. Thanks for the help |
