Old 03-01-2018, 06:00 PM   #1
Fredb_
Fredb_'s Avatar
Default Length of 37 comm drive shaft?
I am looking for the length of the 1937 Ford Pickup drive shaft. Green Bible says part number is 68-4605-B but doesn't give length. Also supposed to be six spline and solid shaft. I am trying to ID one for a friend.
Thanks!
Fredb_ is offline   Reply With Quote
Old 03-01-2018, 07:19 PM   #2
TJ
TJ's Avatar
Default Re: Length of 37 comm drive shaft?
They are the same as the passenger car in length.
Old 03-01-2018, 07:33 PM   #3
Fredb_
Fredb_'s Avatar
Yes, the Green Bible says that too, but looking for the actual length in order to identify possible replacement.
Old 03-01-2018, 08:17 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Actually, I'm fairly certain that '35-'40 are all gonna be the same length, although the '35 & '36 are gonna be hollow and tapered on each end, while the '37-'40 are solid shafts, FWIW! DD
T5 W/TORQUE TUBE
I may not be the BEST, but I'll do 'til he gets here!
Old 03-01-2018, 08:22 PM   #5
Fredb_
Fredb_'s Avatar
OK, the 35-38 Pass and Comm 10 spline are also listed in the Green Bible as 48-4605-A but no length given. Anybody know what the actual measurement is? Thanks for the help.
Old 03-01-2018, 08:56 PM   #6
Brian
Brian's Avatar
A 35-36 [tubular] driveshaft is 68 3/16" long. A solid driveshaft will be shorter, because of the coupling, but with coupling fitted, the overall length should be as above.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 03-01-2018, 09:25 PM   #7
Fredb_
Fredb_'s Avatar
Thanks Brian, I will run with that
Thread Tools
Display Modes
