10-02-2018, 07:20 PM | #1 |
32-34 king pin or 35-36?
How does one differentiate between the 32-34 king pin and the 35-36?
They have different part numbers so I’m assuming there must be something different. Thanks Last edited by Fredb_; 10-02-2018 at 07:47 PM. |
10-02-2018, 09:03 PM | #2 |
Re: 32-34 king pin or 35-36?
the relationship of the retaining notch and the brake actuator, the angle of the opening for the actuator ---on a ford one near the notch is the id
10-02-2018, 09:29 PM | #3 |
Ok, anyone have the distance between the retaining notch and center of brake actuator?
Thanks |
10-02-2018, 11:46 PM | #4 |
Its not so much the distance as the orientation; 32-34 the cotter groove is in the same plane as the flat face on the head, whereas 35-36, the notch is at an angle to the head; left and right hand to suit the appropriate side of vehicle
10-03-2018, 12:40 AM | #5 |
The ‘35-‘36 pins will be parallel to one another if the cups are placed together and the ‘32-‘34 pins will angle apart if checked the same way.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
10-03-2018, 09:24 AM | #6 |
10-03-2018, 10:26 AM | #7 |
This might help a little, I don't think the 1928-31 drawing is correct.
Found this in an old thread. To determine if your king pins are A or B style place the king pin on a flat surface, cup facing down, The shaft of the king pin will angle upward. From the end of the king pin shaft measure to the level surface. A - king pin measures about .700 while a B- king pin measure .950. The B king pin has a steeper angle but unless you have then to compare it is hard to determine. The 35/6 style, the king pin shaft is almost parallel to the surface. Bob Last edited by Bob C; 10-03-2018 at 11:19 AM. |
10-03-2018, 08:58 PM | #8 |
i had a post with a picture of each for ID, i looked, and cant find it. a good example of put the correct title in the post so it can be found in a search !
10-03-2018, 10:21 PM | #9 |
See post below, messed this one up!!!
10-04-2018, 08:01 PM | #10 |
thanks for trying Jerry, but that link wouldn't go for me either
10-04-2018, 08:09 PM | #11 |
10-04-2018, 09:06 PM | #12 |
I have a new set of king pins , labeled 34 , but no brake cups .Does this mean I can use them on a 32 with juice brakes also?
10-04-2018, 09:46 PM | #13 |
That depends on where the notch is in relation to the head
10-04-2018, 11:18 PM | #14 |
10-05-2018, 10:07 AM | #15 |
Even if the cap on top of the ‘37 and later pins was not a stamping only peened on the differences would not allow usage on a ‘36 and earlier spindle. I believe someone may have placed later king pins in the ‘32-‘34 box.
You need to consider the dimension under the top of the spindle to the notch, there needs to be space for the thrust bearing. If your k/p’s measure 5 3/8” long with a notch located 2 1/2” down then they are ‘37-‘41, while the ‘32-‘34 and ‘35-‘36 pins are 5 1/4” with a notch 2 27/32” down. It is the longer dimension to the notch that affords room for the thrust bearing on top of the spindle. The ‘37 and later spindles have a greater span between the yokes for the thrust bearing to be placed below the axle and that is why the dimension to the notch measures less on those. Also, because of the raised projection on the top of the later ‘42-‘48 spindles those require a k/p 5 7/8” long with a notch 2 3/4” down.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. Last edited by Fordors; 10-05-2018 at 11:02 AM. Reason: Clarity |
10-05-2018, 10:41 AM | #16 |
Fordors info is correct, however, there is yet another kingpin not mentioned. English V8 Pilot's run a kingpin, dimensionally the same as 32-36, but without the cup for rod brakes. If 'my4dv8' had a set of those, he could indeed use them in the situation he mentions
10-05-2018, 08:56 PM | #17 |
good info here on this thread, and thanks again Jerry
