Old 10-30-2017, 05:34 PM   #1
Fredb_
Fredb_'s Avatar
Default Difference between RH and LH backing plates?
I am wondering if there is any difference between the RH and LH FRONT backing plates for 1939 hydraulic. I have a set of RH LH here that look identical to me. I also have about 6 marked RH and no LH plates to match them. Thanks
Fredb_ is offline   Reply With Quote
Old 10-30-2017, 05:45 PM   #2
Mart
Mart's Avatar
Default Re: Difference between RH and LH backing plates?
Not 100% sure, but is one of the 4 wheel cylinder holes undersize? Only 3 are used. If you can fit either wheel cylinder, left or right, then the plates could be used on either side.
Mart.
Old 10-30-2017, 05:56 PM   #3
rich b
rich b's Avatar
Other than the stamping they are identical; heard the R/H & L/H designation was to differentiate backing plate assemblies for production.
Old 10-30-2017, 06:47 PM   #4
Kube
Kube's Avatar
There is no difference in fit nor functionality. However, if you plan on having the car point judged, you'll need the "RH" and the LH".
"Imagination is a crutch used by those who lack knowledge and intelligence ."
B
. Franklin
Old 10-31-2017, 05:58 AM   #5
PeteVS
PeteVS's Avatar
I think (and I could very easily be wrong) that there's a couple of degrees difference in the "clocking" of the four holes that bolt to the spindle in order to place the wheel cylinder at the top dead center allowing for caster? Or, is that camber?
Old 10-31-2017, 10:02 AM   #6
Kube
Kube's Avatar
Pete, that would be caster and sorry, but there is no "clocking". The plates are identical sans the stamping "RH" or "LH".
B
. Franklin
Old 11-05-2017, 12:43 PM   #7
Fredb_
Fredb_'s Avatar
Thanks guys, good to know.
Old 11-06-2017, 07:02 AM   #8
PeteVS
PeteVS's Avatar
Sorry for my error. I was thinking F1 front backing plates which do have a difference in clocking.
Old 11-06-2017, 10:45 AM   #9
Tony, NY
FWIW. Rears will work on the front, if you ignore the E brake tube and use the front wheel cyl.
Tony, NY is offline   Reply With Quote
Old 11-06-2017, 04:29 PM   #10
PeteVS
PeteVS's Avatar
And, fronts can be used on the rears if you drill them for hand brake cable tubes. Someone (I should know who) is making the tubes.
Old 11-06-2017, 05:42 PM   #11
rich b
rich b's Avatar
The F series backing plates are "clocked" to the back to permit the hose to clear the king pin boss. The wheel cylinder actually tips even further back than the caster.
