08-05-2019, 07:15 PM | #1 |
Lubrication for Y block water pump shaft (?)
What is that hole in the water pump of my '54 y block? It's about 1/8" in diameter, is at the top of the pump and exposes the inner shaft. It looks like a lubrication port of some type for the shaft, but the shop manual doesn't seem to mention anything about putting lubricant in it. Thanks
08-05-2019, 07:18 PM | #2 |
Re: Lubrication for Y block water pump shaft (?)
It is a coolant seepage hole that alerts you to a bad WP seal.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
08-05-2019, 07:40 PM | #3 |
Thanks again, Kultulz!
08-05-2019, 10:32 PM | #4 |
DO NOT squirt oil down the 1/8 inch diameter hole in the water pump shaft neck casting. If you do, you will be replacing your water pump in less than a week. That hole is only there to allow water to exit when the pump seal goes bad (letting you know that you need to rebuild the pump or get a new one).
08-06-2019, 12:39 AM | #5 | |
That's why I asked. Thanks Dave. |
