05-09-2020, 07:55 PM | #1 |
Speedo drive “turtle” on transmission
Are there different speedometer drives between Ford & Mercury OR are they year specific I.e. 34-37 or 39-42?? I replaced one on the car and the new “used” one looks good, spins nice and free. I installed the cable into the drive and spun the gear and see the cable turning on the other end. I installed the turtle to the transmission but it doesn’t work. I can feel the cable “twitch” but it doesn’t turn!
05-09-2020, 09:16 PM | #2 |
Re: Speedo drive “turtle” on transmission
Tire size and rearend gears depict the turtle gear size more then anything. Fairly certain you can run a 28-29 Model a gear set in the later housings, the Housing may differ. If the picture doesn't come through here there is a chart in my albums.
"Turtle" housing Merc to standard ford maybe different. Just adding useless info. Maybe a bit better rez. Last edited by Tinker; 05-09-2020 at 09:40 PM. |
05-09-2020, 09:44 PM | #3 |
yup, 28-48 all the same
05-09-2020, 11:53 PM | #4 |
Are the gears on the drive shaft all the same?? Newc
05-10-2020, 12:04 AM | #5 |
Believe so. Rear end gears and tire size change the turtle gear section. Now the gear housing is a different question, surely not the same as I probably couldn't put a housing of a 41 on a 33, maybe not. Certainly zephyrs would be very different also.
Probably a good question for a guy like Vanpelts. . Last edited by Tinker; 05-10-2020 at 12:22 AM. |
05-10-2020, 01:47 AM | #6 | |
Interesting info! DD |
05-10-2020, 01:53 AM | #7 |
One or two similar housings fit all Ford Products from '28-'48 to make-up for diameter differences in DRIVEN gears. Check Brattons catalog for all parts except DRIVE gears. Fred MAY have those. DD
05-10-2020, 01:57 AM | #8 |
05-10-2020, 02:30 AM | #9 | |
The different Diameters give the variation of rear end changes. What they do. Brattons is why I mentioned model A gears for 3.54 rear ends. Once you get into the 40's there is different gear housing. Straight verses 90. Or not. Not sure with the 21 gear Zephyr trans its the same. maybe You can run any gear from the chart I posted. Your speedo will be off. But that is all. Last edited by Tinker; 05-10-2020 at 02:37 AM. |
05-10-2020, 03:19 AM | #10 |
The turtle housings aren´t all the same so if someone put a smaller gear in a housing for a bigger gear doesn´t the offset make the gear turn in the air ??
If i get it right...a different housing can put the gear closer to the drivegear to make sure they ingage properly...that´s why we don´t need to change the drivegear. |
05-10-2020, 03:21 AM | #11 | |
Okay I'm on board murre. Makes sense. Like I mentioned the housing is important. gears are set. Now is there a housing change chart??? It'd be anti-ford to make new gears every yr. Not cost efficient. Housing with the same depth but different castings most likely. Last edited by Tinker; 05-10-2020 at 04:29 AM. |
05-10-2020, 03:36 AM | #12 | |
Bratton's has been doing this stuff for a long time. They've done this "turtle" thing more than once! The pictured "9-34" housing in their ad (STRAIGHT housing...not 90 degree) is for a Model 'A' with 3.78 rear gears and 21" wheels. A couple of similar HOUSINGS fit Ford products all the way up to '48! Link to Bratton's ad below...check it out! https://www.brattons.com/catalog.html?cat=446 You make reference to a "21 gear Zephyr trans". Fact of THAT matter is that Lincoln DID offer what are referred-to as both "25-tooth AND 26-tooth" Lincoln Zephyr gears, those two numbers referring to the number of teeth found on the front-most gear on a Zephyr cluster gear. You may know more than I do about Lincoln transmissions, so could you please enlighten me about a "21 gear Zephyr trans"? Nevertheless, most of those heavy Zeps had 4.11 rear ends, necessary to get that heavy-mass automobile rolling from a stop, yet necessitating the corresponding 2.12:1 or 2.33:1 first gear ratios unique to the Lincolns. These were both necessary ratios when facilitating the use of the available O/D. Speedometers could still be calibrated correctly using information from your chart. You'll note that 4.11 is a common rear gear ratio on that chart. Lastly, you state that: "You can run any gear from the chart I posted. Your speedo will be off." Well Mr. Tinker, the whole idea behind using the chart you posted is so that Your speedo WILL NOT be off!.……..DD …………. Last edited by V8COOPMAN; 05-10-2020 at 03:43 AM. |
05-10-2020, 03:47 AM | #13 | |
Not sure what you are getting at. Or why. You agree with the chart, but not me. I don't know you either, I might not like you either. Last edited by Tinker; 05-10-2020 at 04:49 AM. |
05-10-2020, 05:47 AM | #14 |
Hey guys...we here to share and sort out the issues...if you want to find they guy that´s usually wrong i´m the prime suspect...atleast twice a day i have to knock my forehead into the wall
05-10-2020, 05:51 AM | #15 | |
Murrie the only solid info was supplied by you. The rest is just bs supplied by a few that do T5s. Last edited by Tinker; 05-10-2020 at 06:13 AM. |
05-11-2020, 07:19 AM | #16 |
SO.....
What I am pulling from ALL the above IS.......The housing I have is with a high degree of certainty is correct? My issue "most likely" is the actual drive gear?? As I read the chart......with a 16" tire, 3:54 gear set it will MOST likely be a 20 tooth gear??? I will take pictures and post this evening or first thing tomorrow morning if need. Thanks Rockfla Last edited by rockfla; 05-11-2020 at 10:05 AM. |
05-11-2020, 07:30 AM | #17 |
05-11-2020, 08:43 AM | #18 | |
05-11-2020, 08:53 AM | #19 |
I'm not at my car right now BUT I do have a couple of pictures that i took of some other work I was doing and its a little hard to see in the picture because of the glare BUT It looks like " 8 L "???? I can post back this evening when I get home. Or " 8 I " maybe????
05-11-2020, 09:36 AM | #20 |
"DERK".....what a bafoon.....its an 18 tooth gear I currently have on the car!!!! duhha!!!! SO my issue is a "meshing" issue between it and the speedo dirve gear on the output shaft which appears to be in good order from what I see of it when I remove the speedo "turtle"???? AS logic would tell me EVEN IF i have the wrong toothed gear the speedo "Should" work, RIght??? Just not give me an accurate MPH???
