08-14-2020, 11:41 AM | #1 |
1952 stuck flathead
I bought a 52 F100 flathead complete engine but froze up , I pulled the heads cylinders and pistons look very good , very clean no carbon , I fought the valve removal for two weeks , finally got them out today what a JOB , put a socket on the crankshaft pulley and pop it freed up turns smooth and easy , I kinda assumed it was the valve train that was hanging everything up , now my question , should I go ahead a pull the oil pan and check everything , or just work on the top end with new valves , seats , springs ect .and go for it ? , motor still had clean oil in the original air cleaner and oil filter , crankcase oil looked good also , no signs of moister or anything , motor had been setting for 25 years , what do you think ?
Vern |
08-14-2020, 11:51 AM | #2 | |
Re: 1952 stuck flathead
Thanks, Gary in N.Y. P.S. I would also put in some bronze-lined guides, they'll last forever and eliminate any chance of "hanging" a valve over time, been there, done it!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
08-14-2020, 12:44 PM | #3 |
Some plastic gauge, rotate the motor and about 2 hours of your time is "Cheap" insurance both in not only the piece of mind of "knowing" BUT also making "SURE" everything is jam up and jelly tight!!!!
08-14-2020, 02:41 PM | #4 |
It has been my experience that the valve train is most likely the problem with a stuck flathead, cast iron valve guides and steel valves. oil drains out of the valve guides and rust sticks the valves to the guides. I would at the least pull the pan and check the connecting rods for wear with plastigauge . clean the oil pan/screen if they check ok and go for it!
08-14-2020, 02:42 PM | #5 |
the clean looking oil is an illusion. after a long time the dirt settles to the bottom of the pan, and the oil looks new again
08-14-2020, 06:07 PM | #6 |
08-14-2020, 06:44 PM | #7 |
Sounds like good advise from all , think at the very least I'll pull the pan and check the oil pickup screen and just have a look .
08-14-2020, 10:12 PM | #8 |
Plastigauge is a great invention. Rods and mains for sure. For the most part the engines I have checked were in excellent shape. It's a great feeling seeing that wide stripe when you remove the cap!
