07-15-2019, 02:25 PM | #1 |
Isky 1007B Track Numbers
Hello from England.
Some years ago Tom Hutchinson in Baldwin Park, East LA, provided me with an Isky 1007B "track" camshaft but I didn't get a cam card and I can't find a spec. What are the numbers for that cam? www.battenspecial.com |
07-15-2019, 02:40 PM | #2 |
Re: Isky 1007B Track Numbers
Hi Biggles,
Check this thread out. My post #33, the last of that thread, has all three of the 1007s; 1007, 1007B and the 1007LD; listed as "track". You'll have to measure the lift to see which one you have. https://www.fordbarn.com/forum/showthread.php?t=154592 Glenn |
07-15-2019, 03:16 PM | #3 |
That's great - thanks Glenn for the rapid reply.
Isky used to quote opening and closing angles at .020" and .050" lift. Are those numbers available somewhere? |
07-15-2019, 03:43 PM | #4 |
You're welcome!
I don't have those values for the 1007 cam series. Perhaps someone here will see this and post. Glenn |
07-15-2019, 05:51 PM | #5 |
Tell us more about the "Batten Special", especially the engine being build for it now. The heads and intake system are like nothing I've ever seen.
There are flathead powered British specials coming out of the woodwork lately! |
07-15-2019, 07:30 PM | #6 | |
07-15-2019, 07:39 PM | #7 | |
07-16-2019, 04:54 AM | #8 |
It's all in the book !!
Built in 1935 by Ted Batten it's one of the first British flathead specials, along with specials by Sydney Allard, Les Ballamy and the Jensen brothers. It was designed as a Brooklands circuit sports/racer. Those special heads are high compression Federal Mogul copper "Thermo Flow" from 1936-ish, originally with aluminium cover plates which rapidly corroded, later replaced with cast iron covers. I have aluminium copies being machined. In 1938 Ted fitted it up with eight down-draft Amal motorcycle carburetters. It's that engine under re-creation which will be a 21-stud enlarged to 286 ci. Whilst working in LA in the late 1980s Hemmings led me to Tom Hutchinson's Ford Speed Parts Specialties. Tom agreed to build an engine to my spec and estimated $3000. Would he be interested in an exchange deal for an Ardun set? He might. What value would he put on my Ardun set? Oh, about $3000. So the complete Ardun set was carried from England to LA in two suitcases and the deal was done. That engine carried us to many wins in sprints and hill climbs in the UK but is now dismantled so the camshaft could be set up on V-blocks for measuring if some kind if cam follower/lifter can be devised. Edit: managed to get it in my small lathe. The DTI reads .345" lift. http://www.battenspecial.com Last edited by Biggles; 07-16-2019 at 06:24 AM. |
07-16-2019, 06:43 AM | #9 |
Hi Biggles,
It looks like you have the 1007B Lift .355”, adv duration 256*, duration @.050” 236* Glenn |
07-16-2019, 05:28 PM | #10 |
Yes, it's a 1007B per my first post, confirmed by the lift.
So it looks like 17°-59°-59°-17° adv and 7°-47°-47°-7° at .050" Lobe centres both 111° and separation 111°. But Glenn's data sheet shows 20°-55°-60°-15° at unspecified lift for the 1007B. I've emailed Isky for the whole scoop. Thanks for the interest, Barners. I'll report what Isky says. |
07-16-2019, 07:09 PM | #11 |
"Glenn's data sheet shows 20°-55°-60°-15° at unspecified lift for the 1007B."
That is at running clearance. The rate of lift is .008 per degree squared. That info was never published. |
07-16-2019, 11:33 PM | #12 |
"Tom Hutchinson! He was one of my flathead mentors when I was growing up in SoCal."
Tom rebuilt the flathead in my Tonner in May 2006. During the build he took time to educate me about the flathead engine and shared some of the tricks he used when he rebuilt them. He said that the engine in the Tonner would be his last flathead rebuild. I apologize for hi jacking this thread, but wanted to give credit to Tom and his legacy as a builder of flathead engines. Les Williams |
07-17-2019, 07:45 AM | #13 |
07-28-2019, 05:23 AM | #14 |
The cam was fitted in a block and degreed with the DTI directly onto the lifter - no lash -
showing 22-59-63-18° @ .015" lift with max lift .370". Looks like 1007LD ? Intake Ctr. 108° Exh. Ctr. 112.5° LDA 110.5° Advance 2.1° Dur @ .015" 261.5° Dur @ .050" 235° Overlap 40° Last edited by Biggles; 08-13-2019 at 02:51 PM. |
07-28-2019, 09:21 AM | #15 |
Yes, sure looks like it with that .370" lift. Maybe Ol' Ron will comment on durations.
https://www.fordbarn.com/forum/showthread.php?t=156086 So Biggles, I take it that Isky didn't reply to you? Glenn |
07-28-2019, 03:55 PM | #16 |
No, but that was an email message via his website, and oftentimes those are not monitored. But now I have my own figures.
07-28-2019, 05:25 PM | #17 |
Excellent!
07-28-2019, 07:37 PM | #18 |
I'm sure the .355 is correct, but my list is buried someplace in the computer and I can't find it. Nice cam, runs good, needs compression tho.
