02-08-2016, 10:06 PM | #1 |
clutch not disengaging
37 21 stud eng. t5 trans with cornhusker kit with ford type cross shaft. Drake 39 pedal assy.
Clutch does not appear do be disengaging. Things feel correct... small amount of free play and then feel the pressure when pushing down on pedal. When pedal is released can feel the clutch plate push the pedal back up. Measured the travel on the external cross shaft lever and it is 1" then pedal arm travel bottoms out in the little notch in the frame. What is weird is before driveline was put in I had the yoke in trans and started eng and was able to shift through all the gears. Now when I try I cant shift because the gears are spinning. Any ideas? I'm really not looking forward to pulling it apart again. Unfortunately there is no inspection access with this set up. |
02-08-2016, 10:26 PM | #2 |
Re: clutch not disengaging
Clutch disc stuck to flywheel and pressure plate?. Was it sitting idle for an extended period of time?....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 02-08-2016 at 10:33 PM. |
02-08-2016, 10:36 PM | #3 |
No. It was just recently put together. New clutch disc, throwout bearings... from cornhusker. Reused stock pressure plate and flywheel per cornhusker advice.
02-08-2016, 10:39 PM | #4 |
Have you called Cornhuskers about this? I have found them very helpful in the past. Have you tried starting the engine with the transmission in gear and the clutch pedal push down? If it is just mildly hung-up That should free it up (be sure to securely block the wheels!). Could also try pushing the car back and forth with the transmission in gear (and clutch pedal pushed down).
02-08-2016, 10:51 PM | #5 |
Planning on calling them tomorrow. Just getting it all together today. I put rear end up in air, jackstands under axle and started it in gear with clutch pushed in. Wheels turned. Eng died when applied brakes.
02-08-2016, 11:06 PM | #6 |
compatible with your pressure plate .
My Wife Says That I Never Listen to Her, I Think That's What She Said If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
02-08-2016, 11:22 PM | #7 |
02-09-2016, 06:50 AM | #8 |
Sounds like the clutch disc is hanging up to me. Wonder if it is hanging up on the flywheel bolts - potentially in backwards, too thick, ???
02-09-2016, 08:05 AM | #9 |
What pressure plate are you using. Is it a Long style?
02-09-2016, 08:21 AM | #10 | |
I under stand not wanting to take it apart. Double check pedal linkage slop. Maybe with car off the ground start to loosen up the anchor points of the drive line. Cornhusker probably will have input.
Enjoy yer day. Tom Hate can't fix what it started. |
02-09-2016, 01:02 PM | #11 |
Have not gotten thru with Gary at Cornhusker yet but I have a sinking feeling it may be the clutch disc hub up against the pilot bearing.
I will wait to hear from Gary but my guess is, I will end up pulling eng since it has a rear main leak, welch plug leak, and water pumps need rebuilding. What sheet metal needs to be removed to pull eng out of a sedan? |
02-09-2016, 08:05 PM | #12 |
Well just talked to Cornhuskers... he is suggesting to try the original ford arm on the cross shaft linkage.
He said that it should not be a disc issue using the one I got from him, he has had no issues with those. So I guess I will try that arm first when I get a chance to work on it again. Last edited by fftoddster; 02-09-2016 at 08:13 PM. |
02-09-2016, 09:21 PM | #13 | |
02-09-2016, 09:31 PM | #14 |
Well the original arm and aftermarket are both the same length center to center.
I put a length of pipe on the arm and rotated the it as far as it would go (as if applying the clutch) and had my son try to turn the driveshaft (rear wheels in air brakes off) it would not turn. So I am pretty much ruling out external problems such as arm and linkage. It has to be something inside. |
02-09-2016, 09:56 PM | #15 |
What is the free play measurement?
02-09-2016, 10:13 PM | #16 |
tried free play from 1" pedal movement down to practically nothing= no change.
Disconnected linkage all together and manually rotated linkage arm (attached to throw out fork ) as far as it would go clutch still did not disengage. |
02-09-2016, 10:16 PM | #17 | |
02-09-2016, 11:47 PM | #18 |
The drive shaft does turn in neutral, but will not in gear with clutch fully depressed
02-09-2016, 11:53 PM | #19 |
Pilot bearing stub on input shaft bottoming on crankshaft...OR did you install wrong diameter clutch disk?
02-10-2016, 12:50 AM | #20 | |
Input shaft bottoming out? maybe if I loosen trans bolts to bell housing and slightly move trans backward? Maybe I will try that this weekend. |
Thread Tools | |
Display Modes | |
