Old 01-09-2020, 01:38 AM   #1
ironbuttjohn
ironbuttjohn's Avatar
Default torque for master cylinder bolt
What is the amount of torque used on the bolt on the back to the '48 master cylinder? This is the one that holds the brake lines on.
ironbuttjohn is offline   Reply With Quote
Old 01-09-2020, 05:49 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: torque for master cylinder bolt
Have never seen a torque value for it.
Old 01-09-2020, 06:09 AM   #3
Mart
Mart's Avatar
I believe he's talking about the 1/2" threaded banjo bolt that holds the brass distribution block on the back of the cylinder. I don't know the torque. I just use a suitable sized spanner (wrench) and make sure it is tight.
Sometimes you need to use judgement and develop a feel.
Mart.
Old 01-09-2020, 09:36 AM   #4
richard crow
if your using dot 5 use new brass washers & tighten as tight as a craps ass
richard crow is online now   Reply With Quote
Old 01-09-2020, 10:21 AM   #5
fordv8j
fordv8j's Avatar
be careful, I twisted one off...make sure you have the copper washers on both sides of fitting
fordv8j is offline   Reply With Quote
Old 01-09-2020, 10:28 AM   #6
19Fordy
19Fordy's Avatar
No specified torque. Just tighten it up enough to seat and seal in the copper washers.
Old 01-09-2020, 10:36 AM   #7
rotorwrench
rotorwrench's Avatar
If copper washers are new, they should be annealed soft. If they are old, they need to be annealed. It's best to use new but you can heat them up red hot and quench them in water to anneal them. It doesn't take much torque to get a seal. Hollow banjo bolts break easily so snug them good and see if they leak. Tighten until they don't leak within good reason. That's about the best I can say.
Old 01-10-2020, 08:47 AM   #8
Frank Miller
Frank Miller's Avatar
The other thing that is easy to break is the brass fitting when screwing in the brake light switch. I had a hell of a time sealing the one on my 49. Never thought to anneal them first.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 01-11-2020, 02:01 AM   #9
Newc
Newc's Avatar
Rotorwrench has it down. Aircraft spark plugs use copper washers, and we kept a supply of annealed ones for each job. Trainees got to do it. Newc
Old 01-11-2020, 07:13 AM   #10
glennpm
glennpm's Avatar
For annealing copper, rub some hand soap on the washer. Heat it up and when the soap blackens or turns to soot, you have the right temperature. Copper can either be air on water/oil quenched and with keep the anneal, softness, either way. Water quench will remove the black oxide.
Old 01-11-2020, 09:40 PM   #11
PeteVS
PeteVS's Avatar
Thanks! I was just going to ask!
Old 01-12-2020, 07:58 AM   #12
ironbuttjohn
Thanks to everyone for the comments. I have broken this bolt in the pass on another project, real pain in the butt.
Old 01-12-2020, 09:36 AM   #13
Mart
Mart's Avatar
Well, the torque is a bit less than what you used last time then.
Sorry couldn't resist.
Mart.
Old 01-18-2020, 03:44 PM   #14
PeteVS
PeteVS's Avatar
Here's a link to how to anneal copper...
https://www.wikihow.com/Anneal-Copper
Old 01-18-2020, 06:57 PM   #15
Kube
Kube's Avatar
Wink Re: torque for master cylinder bolt
Mart.
Great observation and funny!
Old 07-07-2021, 05:26 PM   #16
zuburg
zuburg's Avatar
So are you saying new copper washers from the parts store such as from Dorman that are described for brake lines need annealing? I thought they would be ready to use since they were described for brake lines?
zuburg is offline   Reply With Quote
Old 07-07-2021, 06:30 PM   #17
51 MERC-CT
51 MERC-CT's Avatar
Only used washers should be annealed in order to re-use.
Old 07-08-2021, 08:43 PM   #18
Ross F-1
Ross F-1's Avatar
Depends. I get my washers at NAPA and they are hard as rock. Not sure if they are Dorman or what.
Got to watch out too, our chinese brothers are putting out copper-coated washers, not clear what's underneath.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 07-08-2021, 11:19 PM   #19
JSeery
JSeery's Avatar
The idea is to soften the copper so it will seal, new or used, they need to be soft.
Old 08-04-2021, 03:19 PM   #20
zuburg
zuburg's Avatar
I don’t have an acetylene torch. Can it be done with a small propane torch like plumbers use to solder copper pipes?
Now I have seen posts that say you don’t need to anneal new washers. The ones I have used show the rings pressed into the copper gasket from the brass block after tightening, but it still leaks. Also, there are no rings on the master cylinder body where the banjo bolt threads in so no rings will be crushed into the copper gasket on the M/C body side. I assume this is normal? So far, I can’t tell if it is leaking on the M/C side or the brass block side of the copper gasket.
Any other ideas to eliminate these leaks? I’ve been fighting this for weeks now.
