11-13-2019, 09:11 PM | #1 |
35 axle housing
I have 4 pair of axle housings to sort thru. I need 1 pair.
What should I look for ??? What is a good bearing surface diameter ??? |
11-13-2019, 10:06 PM | #2 |
Re: 35 axle housing
i would just look for the best bearing surface, and a good diameter would be the ones that measure to be round, or as close to it as possible. they wear on the bottom, and thats pretty forgiving so long as the bearing surface is nice
11-13-2019, 10:08 PM | #3 |
Re: 35 axle housing
The 35-36 housings are often turned over to get better bearing surfaces.
11-13-2019, 10:57 PM | #4 |
Re: 35 axle housing
good point andy! i forgot about that
11-13-2019, 11:56 PM | #5 |
Re: 35 axle housing
You mean flip them from side to side ???
11-14-2019, 12:35 AM | #6 |
Re: 35 axle housing
11-14-2019, 09:06 AM | #7 |
Re: 35 axle housing
The predominant side for wear is the underside of the housing. So if you have a little wear on one side, you can swap the housings to put the worn part on the top side. You don't normally get wear as such, what normally happens is a spalling of the surface.
Thread Tools | |
Display Modes | |
