Old 05-15-2017, 06:03 PM   #1
RawhideKid
Default Rear Axle Keys
Since the rear axle keys are ¼x¼ what is preventing me from using ¼x¼ HSS tool stock?
Before you say it, I know I will need to taper both ends since I have 1 good key as a pattern.
RawhideKid is offline   Reply With Quote
Old 05-15-2017, 06:12 PM   #2
40 Deluxe
Default Re: Rear Axle Keys
The key is basically just a hub locator. If the axle nut is tightened properly, you could remove the key and throw it away and keep going. The fit of the hub on the tapered axle is that good. If the nut is not tight enough, the hub will fret on the axle and bad things will happen!
Old 05-15-2017, 06:16 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
Nothing is preventing you from using it-----but if you are having problems shearin an original key there is a problem with the axle or hub, the taper fit is what prevents rotation, ideally the key is just there, but not really taking any load----if you put in a key that is harder than the axle or hub they will get damaged instead of the key
Old 05-15-2017, 06:27 PM   #4
Art Newland
Art Newland's Avatar
Just put my rear hubs on a few days ago, the repro keys fit great and were cheap.
Art Newland is offline   Reply With Quote
Old 05-15-2017, 06:47 PM   #5
Synchro909
Synchro909's Avatar
The only time the key drives anything is when the taper has let go, usually because the nut is loose. By this time, nasty things are happening in there and you should be able to feel it when you engage the clutch after going from reverse to 1st gear or overrun to drive. If there is any sound from the area or lost motion, things are loose. By having a hard key in there when this happens, you will destroy the axle and/or hub rather than a cheap key (the axle and hub might still be damaged anyway). As has been said above, the key is just there for the ride in a secure hub - it is the taper that provides the grip.
I wouldn't use HSS to make a key.
Old 05-15-2017, 09:02 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
IF you ever SHEARED a key, by GOLLY you'd use the HIGH TONED KEY!!!!--Get REAL!!!
AND, if you're DUMB enough NOT to torque the nut properly, I DON'T feel SORRY for you!
Chief always said, "I'm sorry too, BUT I've lurned to live with it"!---LOL
Bill Nonwalker
"THE ASSISTANT GURU OF STUFF"
Old 05-15-2017, 09:15 PM   #7
Big hammer
Your time is worth more than the cost of new keys, let alone axles and hubs!
Outboard motors have brass sheer pins and for a good reason, to keep from messing up the lower end.
Old 05-16-2017, 04:56 AM   #8
harleytoprock
If the taper is what only holds the grip then why is there a key in there anyway? No reason for hub to axle location orientation.
harleytoprock is offline   Reply With Quote
Old 05-16-2017, 06:34 AM   #9
George Miller
George Miller's Avatar
It is to keep it from creeping. Say you let the clutch out real fast. the key would keep it from creeping. But under normal driving with the nut proper torque it would not move.
George Miller is offline   Reply With Quote
Old 05-16-2017, 08:09 AM   #10
BILL WILLIAMSON
I "think" MANY of us are guilty of this: We wait for the answer we WANT to hear!-LOL
It's just our HUMAN nature. Chief always sed, "Don't CONFUSE me with FACTS, my MIND is already made up"!
Sure miss him, he was a FUN DUDE & LOVED Model As. He was sort of a "self taught" GENIUS, only went to the 8th grade, which was quite common in his day.
Proud Bill W.
Old 05-16-2017, 08:13 AM   #11
SeaSlugs
SeaSlugs's Avatar
I made several sets for my AA out of key stock, didn't take long at all and with a belt sander can match the taper pretty exact. The ford originals had the ford logo with the engine stamp star in between the repeating ford logos...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-11-2017, 02:13 AM   #12
Jeff M
Does anyone have pictures on how the keys look installed? I have some I ordered but they look like the ones pictured with two small tapers on each end. They don't have a long taper on one side like the other pictured.
I've never messed with a banjo rear before. I'm going to lap the axles and hubs but want to get the keys right. Also one keyway is pretty loose towards the taper, how does one fix this?
Jeff M is offline   Reply With Quote
Old 08-11-2017, 06:15 AM   #13
Dave N.
So the taper on the axle and the taper on the hup is a dry fit only, no anti seize to help take it apart many years later?
Dave N. is offline   Reply With Quote
Old 08-11-2017, 06:36 AM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
For sure only clean, dry, and smooth.
Old 08-11-2017, 08:08 AM   #15
Railcarmover
To create a locking taper there is a degree difference in angle between the shaft and hub. I respectfully disagree with Mr Wesenberg in this one area,I use anti-seize on tapers and splines,it doesnt alter the locking value of the taper difference and prevent galling during future disassembly.
Railcarmover is offline   Reply With Quote
Old 08-11-2017, 09:23 AM   #16
katy
katy's Avatar
Just use regular mild steel key stock.
Old 08-11-2017, 10:08 AM   #17
Bob C
Self-Holding Tapers
Fig 2. Self-Holding Tapers
A special case for the beneficial use of friction is 'self-holding' Tapers (Fig 2) for easy machine/equipment component assembly and disassembly such as drill chucks and lathe tail-stock accessories.
A self-holding 'Taper' is an accurately machined tapering shaft and mating sleeve (both of which are dry and clean) that lock together using the coefficient of friction between the two surfaces (shaft and sleeve) and an assembly force (F). If the Taper is machined correctly, the same force (F) will be needed to separate the shaft and sleeve.
If the angle of the Taper is 'exactly right', the shaft or sleeve will be capable of driving the other with no additional assistance for light duty applications and yet part easily with no resultant damage to either of the mating surfaces.
It is important to remember that a plain self-holding taper is only capable of transmitting a force achievable from 'frictional' grip and is thereby limited in its driving capacity. For heavy duty applications the taper is usually provided with a key, the frictional grip providing the holding capacity only.
Old 08-11-2017, 12:18 PM   #18
hardtimes
hardtimes's Avatar
Originally Posted by Bob C View Post
Self-Holding Tapers
Hey Bob,
Very good info for all who care to know details of this matter, and not rely on old tales and hearsay that has been passed on. NOW, maybe this will be passed on and help those with axle problems...but do not know WHY !
Proper amount of Model A axle nut torque has not been discussed, so far.
Just what is the proper amount ? When the number of ft lbs is told, the number is NOT believed by most...why ?
Without new axles/nuts, Model A owners say....oh, that's not right, is tooo much, I just torque them till their tight !
Again, if not lapped right, and not torqued right....nothing is right according to the excellent info that has been provided above.
Old 08-11-2017, 12:34 PM   #19
hardtimes
hardtimes's Avatar
The original keys are cheap/easy to obtain and made as Ford made them to perform intended function. I'd stay with that metal / key.
Because of the fit of the rear axle/hub, I occasionally check/recheck to ensure proper torque. IMO, you WILL be surprised at what you find, that is, that re-torque check is worthwhile.
Only possible exception would be 'perfect' mating/lap joint, IMO.
Old 08-11-2017, 01:24 PM   #20
Al 29Tudor
Al 29Tudor's Avatar
Bob C,
Thanks for the explanation on self holding tapers. The model 'A' axle tapers and hubs, (sleeves) I've seen are everything but accurate and honed tapers. Mine are pitted warn and gouged. And in many cases not torqued to 100 plus pounds. Thanks for mentioning the use for light and heavy load uses for keyed and non-keyed applications.
Al Leach
Al 29Tudor is offline   Reply With Quote
