11-06-2018, 12:34 PM | #21 |
Re: UHaul open car hauler for a Model T?
You had better allow at least 30 seconds to remove the hood! You have to lift the front center at the radiator, then pull it forward 1/2", then lift it clear. No bolts etc. to remove, its weight holds it in place.
11-06-2018, 02:26 PM | #22 |
11-06-2018, 05:02 PM | #23 |
jwilliams
IMO removing the hood is overkill, unless its the early alum. ones. If the hood hooks work, then all 4 corners are secured. If in doubt, pull a pair bungee cords over the hood and lace to the hood hooks. Bungee cords are helpful in towing a T on a open trailer, you can bungee doors closed for safety and bungee the lowered top too. Removing a T hood is easy, pull and twist up all 4 hood hooks so they clear the sides of the hood. Then approach the T from the front of the radiator. Have a nice wingspan to both your arms, pull up each side panel handle, til the sides almost fold together. Then lift, front end first to get the center hood rod free of the open retainer on the radiator shell, then pull up and away to get the hood rod clear of the cowl retainer. Lift the assembly high to keep from scratching the paint on the radiator, cowl, and hood. |
11-12-2018, 04:34 PM | #24 |
Don’t over think it.
A friend who races cars helped me move my Dad’s 1919 Model T and A (separate trips) about 100 miles one way, on his open trailer, on interstate highways. My friend made sure they were tied down securely and stayed below 60 for the trip. We made sure there were no loose pieces, including floorboards and seats before starting out. I suggest that you find someone that races cars and pay him a few bucks to haul your A on his trailer. Most of them respect old cars and understand what they are doing. |
11-13-2018, 11:58 AM | #25 |
There are at least two very active Model T clubs in the Cincinnati area. Suggest that you join one or both of the local clubs. Someone would likely loan a trailer for free to a fellow club member for this little trip. If you need contact info send me a PM.
Cincinnati is a fantastic place to live if you have a Model T.
1910 Touring 1914 Touring 1915 Touring 1917 Torpedo Runabout |
11-27-2018, 05:54 PM | #26 |
Only trouble I have had was that I am required to stop at state borders for animal inspection! The T fits well in an stock trailer! Happy Days! |
11-28-2018, 07:39 AM | #27 |
triple A is 120. for the year and 3 free 100 mile hauls and one 200 haul
whats not to like? |
