Old 10-22-2018, 03:26 PM   #1
Cape Codder
Cape Codder's Avatar
Default Changing Heads Original / High Compression
For those of you that have changed Heads can you tell me if changing from original to high compression requires longer bolts? If so how much difference in thickness is the two?
Thanks for your time.
Cape Codder is offline   Reply With Quote
Old 10-22-2018, 03:46 PM   #2
Dave in MN
Dave in MN's Avatar
Default Re: Changing Heads Original / High Compression
They should be the same.
Good Day!
Dave in MN is offline   Reply With Quote
Old 10-22-2018, 03:50 PM   #3
Synchro909
Synchro909's Avatar
When I changed, I replaced the original head studs with high tensile ones. They are the same length.
Old 10-22-2018, 03:52 PM   #4
Cape Codder
Dave in MN & Synchro909 Thanks to you both for the information!
Old 10-22-2018, 03:52 PM   #5
Charlie Stephens
In general the previous comments are correct but what type of high compression head are you using?
Charlie Stephens
Charlie Stephens is online now   Reply With Quote
Old 10-22-2018, 05:20 PM   #6
Cape Codder
5.5:1 recommended by one of the parts dealers over the 6:1.
Old 10-22-2018, 06:40 PM   #7
Russ/40
Russ/40's Avatar
Did he say why the 5.5 over the 6?
Old 10-22-2018, 10:22 PM   #8
Cape Codder
Easier on the Babbit.
Old 10-22-2018, 10:52 PM   #9
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
What vender was that, just out of curiosity?
Old 10-23-2018, 01:09 AM   #10
DJ S
DJ S's Avatar
I would check the credibility of this source before making your purchase... It seems foolish to purchase a lower compression head when a higher compression can be purchased at the same price. If the babbitt is of concern, a higher compression of any sort shouldn't be installed; the engine should be rebuilt at that point.
Engine rebuilders such as Antique Engine Rebuilding don't even offer the 5.5:1 head anymore for their rebuilds because it doesn't make sense to install the 5.5:1 over the 6:1.
DJ S is offline   Reply With Quote
Old 10-23-2018, 07:46 AM   #11
ryanheacox
ryanheacox's Avatar
If you have a stock distributor with no electronic or centrifugal advance the 5.5 *might* give you a little more wiggle room with where you run your spark lever.
I pay more attention to mine after going to the 5.5 but it still seems forgiving and it tells me when it's too far advanced (usually runs halfway down).
I can only assume that going to 6:1 would mean you have to pay even more attention to the spark advance or go to an automatic advance setup.
Old 10-23-2018, 09:12 AM   #12
old31
Cape, I had 5.5 and then went to 6.1. It made a big difference. If i were you I would go directly to the 6.1, have it checked for straightness and go with grade 8 bolts.
With the 6.1 over a 4.2 and 5.5 you really have to play more with the spark lever especially on hills, no matter how small.
old31 is offline   Reply With Quote
Old 10-23-2018, 12:46 PM   #13
Ernie Vitucci
Good Morning all...I agree with old31, however if the engine is not 'a fresh rebuild', it is a good idea to drop the pan and check the clearances on the mains and rods as you are going to ask them to work a bit harder. Definitely install an oil filter, I use the one from Snyder's that attaches to the valve cover. Even if you run your oil over 500 miles, don't forget to lube all 31 or so zurk fittings each 500 miles to keep down the wear on all the moving parts...Ernie in Arizona
Old 10-23-2018, 02:56 PM   #14
wensum
wensum's Avatar
When I fitted a Winfield 7:1 alloy head, the original studs proved too short and I tried to get a set the length of the stud that holds the distributor cable. That proved impossible so I had to get a new high tensile set made. Unfortunately, only metric stock is available, but the end result was great as they fitted more accurately and the head slipped effortlessly on.
wensum is offline   Reply With Quote
Old 10-24-2018, 07:28 AM   #15
chap52
chap52's Avatar
Duh!
chap52 is online now   Reply With Quote
Old 10-24-2018, 07:33 AM   #16
chap52
chap52's Avatar
Most of the vendors suggest changing out the head bolts to Grade 8 when installing a high compression head because they are less likely to stretch out of torque specs. Makes sense, more compression=more pressure on the hardware.
Worth spending the $40 for the "hopefully" easy replacement. Even if you have to wait on your next Social Security check to cover the cost. Chap
Old 10-26-2018, 02:38 PM   #17
john in illinois
john in illinois's Avatar
The grade 8 studs also have tighter tolerance threads which I think means more than the added strength. I have had some grade 5 s that were very loose fitting in the block.
John
john in illinois is offline   Reply With Quote
