07-29-2019, 05:16 PM | #21 | |
Re: Flathead deck height
Frank |
07-29-2019, 05:34 PM | #22 |
I'm not trying to act superior, I'm just trying to get some basic info. I have deck heights for most all major American OHV engines from the '52 Lincoln (10.94), on but, not the FH.
I know some general info on FH's as I have always loved the look of them and my very first car (1959) was a '48 Merc, with a 3/16 over bore. If you'll read my bio, you'll see my dad worked for a authorized Ford rebuilder from '46 - '51. I started out as a mechanic, at 18 with his tools. I've built many FE's and 289-302 (even had a Edsel, 410 MEL) but, this is only my second FH. My back ground for the last 45 years, has been as a machinist (not auto motive) and I look at all things from that perspective. Frank |
07-29-2019, 05:52 PM | #23 |
The number you all may be wondering about is 10.438".
If we do mill the decks (most builds do get milled) we remove the bare minimum, even though these blocks weigh over 200# they are still "flimsy". It's also the very reason every block gets plate-honed. Thanks, Gary in N.Y. P.S. Haven't found too many to be "dead-on" but they are relatively close considering the machining was done a long time back!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
07-29-2019, 07:44 PM | #24 |
Hey Frank - not trying to argue with you - we actually agree on most things. You and I both know that we can measure something many different ways - as long as we're working from the same starting point, we can get to the same answer. If you want to know what the deck height should be, then all you had to do was read the drawing I posted - it is all right there.
From the Drawing: a) Crankshaft stroke = 4.125 b) Rod Length = 7.000 c) Compression Height = 1.3745 So - the deck height = (4.125 / 2) = 2.0625 + 7.000 + 1.3745 = 10.437 Knowing that Henry tended to use standard increments, the spec was probably 10.4375 or 10 7/16. Now - what I can't say is what tolerance the various flathead production locations actually held. And you asked the question up above: How can you calculate the CH, if you don't know the deck height? Do you assemble a rotating assembly, then measure the deck clearance and adjust you CH from that measurement? In the paragraph above that - I explained that this is exactly what I do. I don't have the luxury of having a block/crankshaft jig all setup for a flathead - to measure from the crankshaft saddle, so I do it the hard way and then I give the machine shop the instructions as to what I want done on both sides and I give the piston manufacturer the corresponding CH. Good luck! B&S |
07-29-2019, 07:46 PM | #25 |
OK, I have a basic question: How do you determine the main bearing bore centerline, in order to get an accurate deck height measurement?
07-29-2019, 08:05 PM | #26 |
You would then measure the other end, to determine if the main bearing bore is in alignment to the deck. If it isn't, it's a good reason to deck the block. Frank |
07-29-2019, 08:19 PM | #27 |
Need to really take it easy on a flathead, the decks are too thin to begin with, not much to work with.
07-29-2019, 08:31 PM | #28 | ||
Many thanks, both of you. I've also been looking for that number for years. Would a 221 block be the same? That's a great drawing, Bored and Stroked, thanks much for sharing it! Is there a chance you did the same for an early engine? Last edited by Yoyodyne; 07-29-2019 at 09:20 PM. |
07-29-2019, 08:37 PM | #29 |
S&B,
I saw that in the PDF but, if you look at my addition of the crank throw, rod and CH, it adds up to 10.503. That would put the piston .065 out of the block. The CH I use, is the replacement piston, that TRW made in 1978, L912F. So, something isn't right. Frank |
07-29-2019, 09:46 PM | #30 | |
The fixture is used to not only square-deck the block, but for all decking operations - as everything is based off of the mains . . . which are indexed/mounted into the fixture. Some fixtures allow you to rotate the block (one deck to the other) - such that you can easily deck one side, rotate it and do the other side the exactly the same way. |
07-29-2019, 09:48 PM | #31 | |
Note: Their dimension for 'Comp Dist' is wrong - here are the basic numbers for the different strokes - which are easy to calculate - just add/subtract from the numbers in my drawing (based on 1/2 the stroke change/difference): 3.750 = 1.561 4.000 = 1.436 4.125 = 1.374 (what my drawing shows - as that is the crank I'm using) 4.250 = 1.311 PS: The drawing is correct - the math works out and matches the 'stocking' pistons that Ross and others supply. What is your math? Last edited by Bored&Stroked; 07-29-2019 at 10:04 PM. |
07-29-2019, 10:13 PM | #32 | |
I don't have the detailed early drawings from Ford (32 - 42 production) - have never seen them. BUT - from the drawings that I have seen, these are the numbers. I did use these dimensions to validate my 42 Merc block - as best as I could manually measure the valve angles, they were extremely close (which was what I was after). Note - this CAD model also shows a 4.125 stroke crank - as I wanted to compare things to the later engines and my particular setup (42 Merc). So - obviously there is some simple math to do to calculate CH - given any stroke. FlatheadFordEngineCrossSection-32-42.PDF |
07-29-2019, 10:53 PM | #33 |
The drawing I have here at my desk does not have the crank CL to deck dimension. It is listed in a different view and that drawing is out in the shop. However, the dimension from camshaft CL to deck is 7.0654 to 7.0704
07-30-2019, 02:02 AM | #34 |
B&S,
What is the origin of your drawing? Frank |
07-30-2019, 02:15 AM | #35 |
07-30-2019, 02:32 AM | #36 | |
Thank you Dale! You are generous! Most folks won't appreciate what you just gave away in terms of hours spent to create and validate that. |
07-30-2019, 07:43 AM | #37 |
Important! Okay guys - was pondering this last night when I went to sleep (you know how it goes) and decided to think back at the purpose of my drawing (which was to look at valve angles and show the CH and crankshaft offset).
For the purposes that I used it for (easy calculation of compression height - given crankshaft stroke and experimenting with rod lengths), it is fine. It doesn't show the block in relation to the crank - which is offset about 3/16. So, the math I previously showed (and the drawing) is fine for determining CH, but not deck height . . . as until I actually add "the block" into the picture, you won't know the number. Hope I'm making sense here - and I owe an apology to Frank! It was not correct to extrapolate deck height . . . when there is no deck to be found in that drawing. |
07-30-2019, 09:10 AM | #38 |
If your a machinist, I'd suggest measuring your deck height on both sides and ask others if they get similar dimensions. Ford had big machines that planed multiple engine blocks at the same time. The 68 series or LB blocks were the last of the pump in head blocks but as I mentioned earlier the deck is thin on all of them so Ford machinists likely set them all up for the same deck height so as not to make them too thin. Not too many folks out there are concerned with the dimension other than they want the deck square, intact, and as crack free as is possible.
If a person has a mandrel to fit the diameter on the main bores in the block, it can be measured from the deck down to the mandrel to get a dimension that can be calculated. The LB was the larger bearing than the previous engines and the first to have removable bearing shells. Last edited by rotorwrench; 07-30-2019 at 09:20 AM. |
07-30-2019, 10:16 AM | #39 |
FWIW, as a quick and dirty check I measured a 37 block this morning. I used a pair of dial calipers from the main bearing saddle to the deck, then added half the bearing bore. The bearing bore looks like 2.590", the saddle to deck looks like 9.150" This is not a great way to measure, and I could only reach at one spot, the front of the driver's side of the block because of the length of the jaws on the dial calipers. So 2.590 /2 = 1.295. 1.295 + 9.150 = 10.445. I'm confident that this is accurate on this block to ±.005. I bought this block disassembled and cleaned and don't know it's history, but it doesn't appear to have been machined at all.
07-30-2019, 03:27 PM | #40 |
Heres my simple thoughts which is similar to what others have written. The actual deck height standard dimension is of no concern to most of us. What is a concern pertains to the decks being exact heights side to side from the crank center line. On every block I have built this dimension side to side has always been different. Seeing your interest is in the rebuild of your engine relatively stock at that to help you get what your looking for you simply need to contact the Ford archives. The Flathead block prints are located there and for a small fee you can get the print which of course will show the dimension your looking for if the print still exists. I have a couple of NOS flathead blocks and they to are not accurate side to side the variations reflect the machining process at the time and the huge amount being produced daily.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
