10-15-2013, 05:44 PM | #1 |
Columbia Guys ?
When at a stop light with the car running, my idle speed increases when I depress the clutch. I have traced it to a vacuum leak within the Columbia shift tank. I assume the leather seals are shot. Who makes a good replacement? I have disassembled it already and put some red grease on them but I am still getting the rpm fluctuation.
10-15-2013, 05:50 PM | #2 |
Re: Columbia Guys ?
Columbia Two Speed Parts www.columbiatwospeedparts.com
Reproduction Repair Axle Parts and Controls for the Columbia Overdrive Two Speed Axle 1935 - 1948
Alan |
10-15-2013, 06:19 PM | #3 |
Re: Columbia Guys ?
John Connelly @ Columbia 2 speed Parts is a great source. I use Neat's Foot Oil (used to waterproof leather boots) to soften and lube the original leather discs in the shift can. Works well on 40 convert top cylinders too.
10-15-2013, 08:01 PM | #4 |
Re: Columbia Guys ?
Make sure your vacumn can is not pitted on the inside. Do not uae grease. Use needsfoot oil on the leather seals. You could also have a vacumn valve leake.
10-16-2013, 06:54 AM | #5 |
Re: Columbia Guys ?
Beside the diaphragm there is a shaft seal. Not only does the cylinder have to be pit free the shaft has to also.
10-16-2013, 06:57 AM | #6 |
Re: Columbia Guys ?
10-16-2013, 08:10 AM | #7 |
Re: Columbia Guys ?
The small shaft seal can be bought locally. When it leaks you will usually see rear gear oil in the cylinder. The only thing I found that works on the leathers is MMO. Everything else including neadsfoot oil get gummy and the shift is not crisp. I have 18 Columbia's and tried all types of oils. Make sure you have at least 3/8" ID hoses, fittings and tubing. G.M.
www.fordcollector.com |
10-16-2013, 05:08 PM | #8 |
Re: Columbia Guys ?
And I solved my leak problem by using hose clamps at each rubber hose end.
Thread Tools | |
Display Modes | |
