11-03-2019, 09:11 AM | #21 |
Re: What revs at 60MPH
I work on modern cars, next time you are stopped in traffic and there are cars on each side, in front, and back one of those cars has a much more serious problem than old near bald tires ---- tires,suspension,brakes that the owner knows about and declined the repair ---tires showing 2 layers of cord, inch or more play in ball joint ---siezed brake calipers, rusted brake pipes with one line crimped off ----I see this work declined every day, but the radio, sunroof get fixed!
11-03-2019, 11:14 AM | #22 | |
That is similar to what I have heard... At 50 MPH my engine is at 2200 RPM. (Using Tach and GPS). Last edited by Ruth; 11-03-2019 at 11:21 AM. |
11-03-2019, 01:15 PM | #23 |
You would also need to consider 28-28 vs 30-31 (21" vs 19") wheel diameter, as the rolling diameter of the tire will have an impact on speed at any given RPM with the same ratio rear
11-03-2019, 09:34 PM | #24 | |
40 to 45 is an enjoyable speed, but you need to find some good Wisconsin roads for that. Too many fool drivers in Minnesota. |
11-04-2019, 12:16 AM | #25 |
According to Lucas Classic Tires a 28/29 tire (4.40/4.50-21) is a ¼" taller than a 30/31 tire (4.75/5.00-19). I don't think you would see much impact.
11-04-2019, 01:25 PM | #26 | |
My Truck had 4.11, could not keep up with others, so had 3.54 installed. I like a relaxed slower pace and drive anywhere from 30 - 45 mph max. Live in a small town of about 20,000 people in Wisc, stay away from Interstates, busy state and county roads as much as possible. I tense up and do not enjoy those roads. Some times go out exploring, getting lost, and use Google Maps on my cell phone to find my way home. |
11-04-2019, 01:54 PM | #27 |
I like this website for calculating RPMs and speed at a given RPM. http://www.grimmjeeper.com/gears.html
Like others, I don't think I'd want to cruise at 60 for many reasons. I did see if my car with it's new engine could do it and yes, it can do 65 but I didn't keep it there more than 30 seconds. In my rural area cruising at 50-55 is safely doable and my car seems perfectly happy to do it. That's about 2200-2400RPM. |
11-04-2019, 07:15 PM | #28 |
From 32-37 service bulletins
11-04-2019, 07:53 PM | #29 |
All steel from pedal to wheel |
11-04-2019, 08:19 PM | #30 |
11-07-2019, 03:50 AM | #31 |
That is a fantastic chart..
Thank you all for your responses. Steve N.Z. |
