Old 03-01-2018, 10:40 AM   #1
Topher5150
Default 1947 running boards
So it looks like my aluminum running boards are still in pretty good shape, apart from some damaged bolt holes, the oxidization looks pretty minimal, and the stainless looks to be in decent shape. Even though they look usable visually do they hold up pretty over time?
Topher5150 is offline   Reply With Quote
Old 03-01-2018, 11:59 AM   #2
Kube
Kube's Avatar
Default Re: 1947 running boards
If they are as you describe, they will most likely last as long as you will need them to.
Old 03-01-2018, 12:46 PM   #3
RalphM
RalphM's Avatar
On the subject of 1947 running boards, what is the best way to replace damage cage nuts that hold them on?
Access to them seems very limited. Thanks.
RalphM is offline   Reply With Quote
Old 03-01-2018, 01:16 PM   #4
Topher5150
I have to replace the rocker boxes on both sides anyways, but maybe cut some holes in the rocker boxes, and weld in some new nuts and patch it back up with the metal you cut out.
Old 03-01-2018, 03:12 PM   #5
RalphM
RalphM's Avatar
I thought of that way, can any be accessed from inside?
Old 03-01-2018, 03:27 PM   #6
Kube
Kube's Avatar
Nope, they can't be accessed anywhere but the inner rocker. I'd recently completed a ground - up restoration and found it necessary to replace a number of those caged nuts. I had to cut open the inner rocker, replace the nuts and cages and weld new patches in so no one would ever know I was "in there".
Old 03-01-2018, 05:45 PM   #7
RalphM
RalphM's Avatar
Ok, looks like I’m in for fun
All the running board bolts pretty much snapped off in drivers side when I pulled it.
I expect the same with pass side.
Old 03-01-2018, 07:12 PM   #8
FortyNiner
FortyNiner's Avatar
The replacement rocker pieces that I bought from EMS had the cage nuts already installed at about the right locations. Really simplified that part of the reassembly.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 03-01-2018, 08:40 PM   #9
RalphM
RalphM's Avatar
So what’s involved in changing the entire rocker?
This car is sill on the frame, although I am putting new body mounts in.
Old 03-01-2018, 09:15 PM   #10
FortyNiner
FortyNiner's Avatar
My old ones were mostly memories - there was some tidying up to prep the space for the new pieces. These need to be trimmed to fit before welding into place. In my case, there was also some floor patch work that followed the rocker fixes.
Old 03-02-2018, 12:11 PM   #11
Graeme / New Zealand
Graeme / New Zealand's Avatar
Mine was done that way before i bought the car as a half finished project. It still has the holes cut in the inside of the rocker box, I'd thought about covering them but then thought what the hell the cars not going to get dragged through a lot of crap.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 03-03-2018, 10:45 AM   #12
Kube
Kube's Avatar
GB
Rest assured, I would have preferred not to repair the holes but this was a total restoration so I saw no other option.
Old 03-03-2018, 12:03 PM   #13
oldskool
oldskool's Avatar
the rockers had been replaced on my 1946 merc and had no holes in them but I had the alum running boards that came with the car , I held them in place and marked the holes and drilled them to except 5/16x18 nutserts and used a running board mounting hardware kit,,,worked great
oldskool is offline   Reply With Quote
Old 03-03-2018, 06:29 PM   #14
Topher5150
since we're on the subject of rocker boxes, and it's my thread, does anyone have any build pics of rocker box replacement?
Old 03-04-2018, 12:27 PM   #15
FortyNiner
FortyNiner's Avatar
I'm not so hot at remembering to take in-progress pics. This is all I've got:
Old 10-05-2018, 06:46 AM   #16
Topher5150
Pulled off the drivers running board last night and they look like it might be a lot of work to salvage them. Might be better off bending up some new ones at work.
Old 10-05-2018, 03:40 PM   #17
supereal
supereal's Avatar
Recheck the position of the spark plug wires in the distributor. Remember that the number one cylinder is the first from the front on the passenger side, all the rest have to inserted in the firing order.
supereal is offline   Reply With Quote
Old 10-05-2018, 03:48 PM   #18
Topher5150
Looks like you posted on the wrong thread
Thread Tools
Display Modes
