Old 10-19-2019, 08:32 AM   #1
M2M
M2M's Avatar
Arrow What do you make of this
M2M is offline   Reply With Quote
Old 10-19-2019, 08:40 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: What do you make of this
Used head??
Paul in CT
Old 10-19-2019, 08:54 AM   #3
cjkohnast
Wires too long
cjkohnast is offline   Reply With Quote
Old 10-19-2019, 09:01 AM   #4
Jacksonlll
Jacksonlll's Avatar
Someone trying to make a new engine look old????
Old 10-19-2019, 09:07 AM   #5
Patrick L.
Patrick L.'s Avatar
Well thats certainly different, and 12v.
I like that primary ignition cable. Wish I had another one. I like the old small diameter flexible replacements. It seems no one sells them anymore.
Old 10-19-2019, 09:15 AM   #6
Y-Blockhead
Y-Blockhead's Avatar
Try MAC's... https://www.macsautoparts.com/ford_m...red-cable.html
Old 10-19-2019, 09:21 AM   #7
veggie
veggie's Avatar
Send a message via AIM to veggie Send a message via Yahoo to veggie
The red wire goes into the OIL FILL
veggie is offline   Reply With Quote
Old 10-19-2019, 09:32 AM   #8
History
History's Avatar
Timing is off and the head is cherry red?
History is offline   Reply With Quote
Old 10-19-2019, 09:58 AM   #9
M2M
M2M's Avatar
Are those plugs 7/8"?
Old 10-19-2019, 11:59 AM   #10
Patrick L.
Patrick L.'s Avatar
Originally Posted by Y-Blockhead View Post
Thanks. Never thought of Macs. I stopped using them years ago, even though they are close, due to problems.
A new cable has been ordered.
I don't care for dealing with that fat stiff cable.
Old 10-19-2019, 12:48 PM   #11
ursus
This engine is sporting one of those High Corrosion Heads recommended by Ferrous Buehler for a fine rustoration. With the accessory acorn nuts it provides a horsepower boost you can feel in the seat of your pants.
Old 10-19-2019, 01:16 PM   #12
Purdy Swoft
Purdy Swoft's Avatar
I like the acorn nuts .
I use the acorn nut covers on some of my engines
. The acorn nuts were popular with the flathead V8s .
They are real good for covering up or hiding head studs and nuts that have been painted , for a fresh or cool look .
The nut covers that I use can fairly easily be slipped off by hand , whenever I may need to tighten or retorque the head .
I' haven't had one of the nut covers slip off and get lost
Packard use to use acorn nuts on some of their engines so I have been told.
If the Packard acorn nuts fit the Ford flathead V8 , they will also fit the model A .
Old 10-19-2019, 01:24 PM   #13
eagle
eagle's Avatar
"What do you make of this
Not sure what you're getting at. See some different ways of doing things, like not painting the head before it's installed? Or wiring? or sparkplugs? or the friction taped wiring harness on the firewall? or ??
Old 10-19-2019, 01:27 PM   #14
F.M.
Originally Posted by M2M View Post
A fire looking to happen !!
F.M. is offline   Reply With Quote
Old 10-19-2019, 03:03 PM   #15
Patrick L.
Patrick L.'s Avatar
Old 10-19-2019, 03:49 PM   #16
duke36
Head leaking, extra clamp for thermostat at upper gooseneck? 4 blade fan to be changed to 2 blade for safety?
Old 10-19-2019, 04:17 PM   #17
M2M
M2M's Avatar
Regardless of what we all think, if this car was for sale at a classic car dealership we would see phrases like "quality restoration"; "100% original"; "turn-key" in the advert.
Old 10-19-2019, 07:01 PM   #18
Y-Blockhead
Altho I have never had a problem with MAC's, I don't usually use them either. But I find that they usually have things that other venders don't carry.
Old 10-19-2019, 07:16 PM   #19
larrys40
Someone put in a new head and didn’t paint it for one ....
Then, unknown if it’s 12 volt with a ballast resistor and someone doesn’t know how to not do they understand the model a wiring . Fix it to stock and you will be fine
Larry Shepard
larrys40 is offline   Reply With Quote
Old 10-20-2019, 09:18 AM   #20
Patrick L.
Patrick L.'s Avatar
I don't feel like driving to Lockport so they are sending it. Its on its way. I used to like Macs and talk in person to them, but, that changed some time ago. I've not dealt with them since Ecklers took over.
