Old 03-09-2018, 11:53 AM   #1
kimeccles
kimeccles's Avatar
Default 1930 Cabriolet hood/cowl band retainer
Cabriolet and deluxe owners,
Is this stainless combination hood to cowl retainer correct for a mid-later 1930 Cabriolet? Currently I just have the painted one, but can't find anything in the judging about this style which seems a lot nicer to me to match the SS cowl band also so the two parts do not rub together.
Thanks
[IMG][/IMG]
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930.
kimeccles is offline   Reply With Quote
Old 03-09-2018, 01:01 PM   #2
160B
160B's Avatar
Default Re: 1930 Cabriolet hood/cowl band retainer
RG&JS page 15-7 has some information on the hood hinge bracket but is not clear which vehicles had the chrome plated brass or stainless steel hood hinge bracket.
There is no information on this bracket in section G Cabriolet of the RG&JS
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 03-09-2018, 03:07 PM   #3
kimeccles
kimeccles's Avatar
Thanks. I do see it was mentioned in judging where you reference. Bratton's says it was used on "some" deluxe models. I think I may get it in SS as it should match up well with the SS cowl band.
Old 03-09-2018, 03:18 PM   #4
jw hash
jw hash's Avatar
try to find a original. almost all the repro`s do not to fit worth a s--t. some of them you can grind and make them work, I have never seen a plated brass one.
jw hash is offline   Reply With Quote
