12-17-2012, 11:48 PM | #1 |
1928 A clutch
I have a couple of good manuals,but they don't have any info on the early "28" clutch. I pulled the engine,and was surprised to see it looked like the inside of a automatic trans,with that big drum. Does any one know of a manual that has info & specs on this. I haven't seen any parts for these either! Thanks.
12-18-2012, 12:06 AM | #2 |
Re: 1928 A clutch
DON'T take the set of clutch plate with teeth on them apart. They will flyapart and cause injury.
12-18-2012, 12:14 AM | #3 |
Re: 1928 A clutch
The Service Bulletins have good info on the 28 clutch. Also some good detailed instructions can be found on Jim Masons website. As already stated do not just unbolt the clutch pack without the proper fixture or you will likely be seriously injured. Rod
12-18-2012, 12:27 AM | #4 |
Re: 1928 A clutch
Model A Ford Service Bulletins Complete....is a yellow hardcover book available from most vendors. It features 5 pgs outlining a basic teardown with some points to check & several good pictures showing specialized KRW tools at work.
There also was a 3 ring binder version with nice big pages. I believe it's currently unavailable. PS .........sorry.... Rod posted the same info up above as I was huntin & peckin! Last edited by Craig Lewis; 12-18-2012 at 12:32 AM. |
12-18-2012, 12:27 AM | #5 |
Re: 1928 A clutch
The Service Bulletins pp 221-224 explain how to work on it, but I'm with the others: this is a tricky business and requires special tools.
12-18-2012, 12:40 AM | #6 |
Re: 1928 A clutch
http://www.ocmafc.org/techarticles/Tom%20Endy's%20Special%20Topics/Multiple%20Disk%20Clutch.pdf
12-18-2012, 01:02 AM | #7 |
Re: 1928 A clutch
Here is a link to the instructions found on Jim's website. Rod
http://jmodela.coffeecup.com/clutch.html
12-18-2012, 03:13 PM | #8 |
Re: 1928 A clutch
No specialized tools needed. Just use 4 pieces of 1/4 inch stock with an inexpensive hose clamp. Use a press to hold pressure on the center spring until you can remove the four nuts, and slowly release. The 1/4 inch stock fits the teeth nicely and prevents them from moving. |
12-18-2012, 03:33 PM | #9 |
Re: 1928 A clutch
Brian-NJ:
I have heard of people making up some type of jig, but this looks very simple and easy to make. Very good suggestion. Tom Endy |
12-18-2012, 04:12 PM | #10 |
Re: 1928 A clutch
I agree Brian. You have an excellent idea. I've always used 2 screwdrivers with 1/4" round shafts.
I use an 18" piece of threaded rod with some nuts and washers to take the pack of discs apart. |
12-19-2012, 08:29 PM | #11 |
Re: 1928 A clutch
Thanks for all your sugestions & picture.
