09-16-2017, 01:58 AM | #1 |
49 Mercury Trim clips ?
I'm looking for the trim clips for the chrome pieces that run along the windows on the left and right side 3/4 x 3/4 anyone know where to get them ?
Thank you |
09-16-2017, 08:54 AM | #2 |
Re: 49 Mercury Trim clips ?
If you do a flea-pay search look for Belt Trim or molding of appropriate year Mercury. The 3/4" spring clips should come up. Now if its lower door trim then look for that.
A lot of the late type replacement stuff is bolt on so that would be difficult if not impossible for belt trim pieces. The door trim pieces only have a few bolt on clips but they are located where you can get to them and there are only a few of them per side. Last edited by rotorwrench; 09-16-2017 at 02:40 PM. |
09-16-2017, 05:14 PM | #3 |
Try Restoration Specialties, www.restorationspecialties.com, 814-467-9842. They have a great catalog and probably have your clips.
09-17-2017, 12:38 AM | #4 |
Ok thanks. I'm looking for the trim right under the window not the trim on the door.
I will look at restoration specialties I have got some stuff from them before. |
09-17-2017, 08:08 AM | #5 |
I have the trim clips with the dot of rubber to seal the hole or not [email protected]
09-17-2017, 08:15 AM | #6 |
09-17-2017, 01:36 PM | #7 |
Thank you, I will message you
