04-03-2021, 09:51 AM | #1 |
36 pickup rear view mirror location
Adding a rear view mirror to my pickup, not sure where it goes. Did not have one or any holes for one. In the middle of the upper dash, or a specific measurement. Thanks for your help. Ron
04-03-2021, 09:59 AM | #2 |
Re: 36 pickup rear view mirror location
Ron ours didn't have a rear view mirror when I bought it, but I found two very small divits in the paint where they had sanded and slightly filled and painted over the mounting holes. Check your's out, maybe take the wiper panels off and look behind the upper panel for a clue.
This doesn't answer you question, and if I can get over to the garage where the '36 is stored I'll try to take some measurements. |
04-03-2021, 10:57 AM | #3 |
Thanks for the reply, I will check it out. Ron
04-03-2021, 01:04 PM | #4 |
35-36 Ford pickups did not come with an inside mirror, only one outside mirror mounted on the driver's side. That's probably why the guy filled and sanded the holes where a PO had mounted one because he knew they did not come from the factory with an inside mirror.
Henry probably thought, hey, this is a work truck and the bed is gonna be full of "stuff" and the driver won't be able to see out of the back window anyhow, so we can save 5¢ per vehicle. That's probably why trucks didn't come with white walls as well. These were WORK trucks. I believe 37 was the first year that came with an inside-mounted mirror, but I'll let the 37 pickup experts answer that one. FWIW, I added an inside mirror on Apatchy for safety reasons. I am 5'8' and I mounted a 46-48 style mirror in the center of the header panel over the windshield where said panel curves under toward the windshield and it suits me just fine. Looks nice as well.
Life is like a roll of toilet paper. The closer to the end, the faster it goes. It is better to be seen, than viewed. "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". Last edited by Lawson Cox; 04-03-2021 at 09:25 PM. |
04-03-2021, 03:05 PM | #5 |
I added a mirror to my '38 and it barely works because the rear window is so short and the mirror mounts high. Can't lower the mirror or it would interfere with vision through the front windshield so I have to bend down to use it and I'm only 5'-8". Don't know about your '36 but you may be better off adding convex mirrors to the doors.
04-03-2021, 09:50 PM | #6 |
04-04-2021, 09:05 AM | #7 |
'32-'37 pickups and trucks (as mentioned) did not have interior mirrors; but it is "your" truck so do what you feel comfortable and safe. When I first had my '34, it had an interior mirror but the cab had "extra" holes above for placement for an interior mirror.
04-04-2021, 10:30 AM | #8 |
I believe, but am not 100% certain, that 1940 was the first year they were an option in the pickup trucks.
They are, as a few have you had stated, completely worthless.
04-04-2021, 10:51 AM | #9 |
Here are pictures of the rear view mirror that I mounted in my '34 PU. Used a mirror mount from a '35 sedan. Mike
04-04-2021, 11:16 AM | #10 |
I have one in my 36, had no idea it was not original. I could not imagine not having it though.
04-04-2021, 11:21 AM | #11 |
Hear are some photos of the mirror in my 36, it was in the truck when i got it, and it was moved over by someone in the past, uou can see the old screw holes. I don't know what the mirror is from
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
