08-15-2019, 04:37 PM | #1 |
Please help ID these springs.
I got them (there’s 2) with some stuff that was supposed to be ‘36 stuff but these clearly aren’t by the way the spring wraps around the end. Does anyone have any ideas?
They are 36” eye to eye and 10 leaves. Eye Clip Any help would be appreciated so that I may properly label them when I try to move them. |
08-15-2019, 05:21 PM | #2 |
Re: Please help ID these springs.
The later production Ford springs had the wrap around second leaf, and it also could be a aftermarket replacement
08-15-2019, 08:02 PM | #3 |
That's aftermarket.
Also, the width is of little help in identifying a spring unless you know the length at a prescribed height / weight.
08-15-2019, 08:15 PM | #4 |
Hope that helps. |
