02-07-2019, 08:57 AM | #1 |
Can Anyone Identify the Heater Needed for This Manifold?
I have a split waffle style manifold but not the heater cover. The mounting bolts are a lot farther apart than the 7" on the commonly available Autolite part (they roughly align with the #1 and #4 spark plugs). Does anyone recognize this and know what brand it is? I'd like to put heat in my car.
02-07-2019, 01:29 PM | #2 |
Re: Can Anyone Identify the Heater Needed for This Manifold?
That looks like an Autolite heater manifold that someone has modified for easier distributor access.
AL in NY |
02-07-2019, 02:24 PM | #3 |
That would be a heater called "Director".
02-08-2019, 12:55 AM | #4 |
It looks to me that it is a Autolite heater that has been modified, However, from what i see, the hole in your firewall is located for a Otwell manifold heater. That is what I would look for as the Autolite would require cutting a new hole in your firewall. Disadvantage to the Otwell is that you can't remove the cover for summer driving...
Hope this helps answer your question.. |
02-08-2019, 11:36 AM | #5 |
I have seen this style before but don't know the name. It might be a Director but I have a Director Special but it is solid and doesn't have a removable top. But then again it might be a different model. I also agree that you will have to find a different one to use or create a different opening.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
02-08-2019, 11:48 AM | #6 |
I may be in for fabricating something on my own or just replacing it with a more common manifold/heater assembly. |
02-08-2019, 12:11 PM | #7 |
The lip at the rear for the common Autolite is rounded,this one is square.I have one something like this one,but it is a little different.Mine is marked Director number 9,or number 7.It is marked on the cover.I'm actually getting a bunch of Model A heaters together,I always bought them when I found them.Never really had a use for one,so I will be getting pictures to peddle them off.
02-08-2019, 01:14 PM | #8 |
I have seen a lot of those manifolds, there is three of them on Ebay right now. beats me the brand. but they are NOT autolite or Red Head.
02-10-2019, 06:15 PM | #9 |
Keith,
If and when you have any pictures please let me know. The attachment bolts are 10-3/8" apart on my manifold. Thank you. Dean |
