Old 02-16-2019, 11:36 AM   #21
Smooth_One
Smooth_One's Avatar
Default Re: Vintage Precision thermostat housing
Originally Posted by Benson View Post
Please tell me where I can find the link that Werner posted?
I do not see a link on Werner's post ...
Did I miss something?
http://www.stant.com/index.php/engli...at-thermostat/
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 02-16-2019, 03:13 PM   #22
Benson
Benson's Avatar
Ok thanks...
I STILL do not see a link in Werner's post #16 …
The link that YOU posted in post 21 is the link that I posted in post 15.
... Thought that I missed some info I did not know about
Old 02-16-2019, 03:29 PM   #23
Pete from OZ
Pete from OZ's Avatar
Is there a Gasket used between the Housing and Head, Or do you just use a Sealant. Thanks
Pete from OZ is offline   Reply With Quote
Old 02-16-2019, 05:12 PM   #24
AL in NY
AL in NY's Avatar
Just sealant works best and you don't have to worry about breaking an ear off your new thermostat housing.
AL in NY
AL in NY is offline   Reply With Quote
Old 02-16-2019, 06:23 PM   #25
Smooth_One
Smooth_One's Avatar
Yes Casey from Vintage Precision said to just use RVT or equivalent. No gasket.
Isaiah B.
Old 02-16-2019, 07:33 PM   #26
Smooth_One
Smooth_One's Avatar
Radiator out. Shaft of the water pump was really loose so I’m glad I caught that.
Isaiah B.
Old 02-17-2019, 08:11 AM   #27
Smooth_One
Smooth_One's Avatar
Out in the garage last night til after midnight.
Isaiah B.
Old 02-17-2019, 08:53 AM   #28
30 Closed Cab PU
Hi Smooth One
From what I can see in the pictures your cooling system is really clean.
What do you use for coolant?
Was the cooling system recently flushed with, if yes with what method (Water, Vinegar, thermocure, etc)?
Old 02-17-2019, 05:22 PM   #29
Smooth_One
Smooth_One's Avatar
Originally Posted by 30 Closed Cab PU View Post
Hi Smooth One
I recently flushed it with CLR and Vinegar, poured both in and let it run at just above idle for about 30 mins then let it sit overnight then drained everything out and flushed with water.
I’m running Green coolant 50/50 with distilled water and a bottle of Redline water wetter additive.
I spent an hour and a half cleaning the gasket surfaces last night.
Isaiah B.
Old 02-18-2019, 12:31 PM   #30
30 Closed Cab PU
Thanks for the info, 1st I've heard of mixing CLR and Vinegar. Seems running anti freeze/redline and using your flush concoction works well.
Am interested, a new Bergs is going on mine, want to protect the investment.
Old 02-19-2019, 12:25 PM   #31
Smooth_One
Smooth_One's Avatar
Such a nice piece!!
Isaiah B.
Old 02-19-2019, 12:43 PM   #32
Smooth_One
Smooth_One's Avatar
I should have the cooling system back together by the weekend so I'll keep you guys updated with pictures and running status.
I talked to Steve at Bert's and he said they all run these pumps in they're cars and have NEVER had an impeller come loose, because I called him and asked if i should drill/pin or spot weld it and he said no and assured it won't move. So I'll run it as is.
He said put it on, put a small bit of grease in the REAR Zerks fitting and let'er rip!
Isaiah B.
Old 02-21-2019, 12:45 PM   #33
Smooth_One
Smooth_One's Avatar
Going back together.
Isaiah B.
Old 02-21-2019, 06:18 PM   #34
37 Coupe
37 Coupe's Avatar
I have a question on the Bert's water pump which I may order one as the Bratton's one is an issue. Is the shaft stainless and also brass? It looks like brass color on fan end in pictures.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 02-21-2019, 07:33 PM   #35
Smooth_One
Smooth_One's Avatar
I believe it is just Heat Treated stainless steel.
I think what you’re seeing is an anti-corrosion coating I’m guessing. I can call them tomorrow and ask.
Isaiah B.
Old 02-21-2019, 07:35 PM   #36
Smooth_One
Smooth_One's Avatar
The pump it self feels a bit heavier And at least the one I received looks a little bit thicker all the way around the casting.
Isaiah B.
Old 02-22-2019, 08:49 AM   #37
Tom Wesenberg
Tom Wesenberg's Avatar
Your first picture in #33 shows that you have a Canadian Powerhouse generator. Usually only see them on cars near the Canadian border or Model A's that Canada sent overseas.
Old 02-22-2019, 09:16 AM   #38
Railcarmover
Originally Posted by Joe K View Post
What? No broken ears to contend with?
How can one be a Model A owner and not broken his ears?
Kidding of course. Ford design was a "work in progress" as evidenced by the three bolt Model B water-pump.
Joe K
Ford engineering noted a number of improvements needed for the original A engine as the A was produced,but Ford held them till the B engine was introduced.Most noticeable was the main bearing issue,Ford engineers knew of the A engine weakness of the crankshaft and the propensity for center main bearing failure during engine development.The issue wasn't addressed till 1932,with the B engines bigger main bearing journals and pressure lubrication.
Railcarmover is offline   Reply With Quote
Old 02-22-2019, 11:47 AM   #39
Smooth_One
Smooth_One's Avatar
Tom yes the engine number starts with CA so it is Canadian.
Isaiah B.
Old 02-22-2019, 12:41 PM   #40
J Franklin
J Franklin's Avatar
Wasn't the problem you had with the new water pump actually your modified head? I'm sure the pump Brattons sold you was as good as anyone else sells.
