Old 02-14-2019, 11:53 AM   #1
30Ford
Default Genarator
Are there any good links for Model a generators ...Had mine rebuilt and it does not charge ...I have a feeling that the field coils are backwards Just want to do some reading ..checked this site and did not find what i wanted
thanks
30Ford is offline   Reply With Quote
Old 02-14-2019, 12:59 PM   #2
Charlie Stephens
Default Re: Genarator
thanks
Did you, or the person that rebuilt it, polarize it?
Charlie Stephens
Old 02-14-2019, 02:09 PM   #3
30Ford
yes
Old 02-14-2019, 04:22 PM   #4
Herb Concord Ca
If you have a voltmeter, with motor running, measure the generator output to ground, if the voltage is positive, try reversing the 2 field coil wires. Then polarize the generator. That should solve you problem.
Herb Concord Ca is offline   Reply With Quote
Old 02-14-2019, 04:52 PM   #5
Patrick L.
Patrick L.'s Avatar
Does it motor if you jump power to it ?
Old 02-14-2019, 11:21 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Do an advanced search here for keywords "generator testing" and user "Tom Wesenberg"
Also you can check out; https://www.vintagefordforum. com/fo...r-installation
(take the space out between the dot and the com)
