02-03-2019, 05:56 PM | #1 |
Question? Peened inner front wheel bearing
My right front inner (the larger)wheel bearing has been Peened to the front spindle. What is the best way to ensure that I have enough grease loaded into the bearing, as I can't remove it from the spindle? I have used needle adapter for my grease Gun-- seems to work
Thanks for your Help! HS |
02-03-2019, 05:59 PM | #2 |
Re: Question? Peened inner front wheel bearing
You Also Email me at [email protected]
02-03-2019, 08:27 PM | #3 | |
02-03-2019, 09:23 PM | #4 |
If the outer bearing fails you have a potential to loose steering no mater how the inner is held on? I guess I do not understand how having the inner bearing staked to the spindle (many cars have had that done) affects the preload and will cause loss of steering if outer bearing fails. ? I would agree that a better spindle would be best course of action in any case.
I know the voices aren't real but damn they have some good ideas! |
02-03-2019, 10:30 PM | #5 |
Hi Brent
Hugh, here in Virginia, The inner bearing is Holding good to the Snout of Spindle Outer small bearing is fine. Hugh |
02-04-2019, 07:12 AM | #6 | |
Ok, I see what you are saying. Remove the drum/hub and then remove the inner bearing. Take a file and keep working the raised areas down until the bearing has a nice 'slip fit', -then repack it with grease and install normally. |
02-04-2019, 12:53 PM | #7 |
Hi Brent,
OK, Got that, But the The inner Bearing is on the spindle Very Tight! I'm not sure I can get it off the spindle without damaging the Bearing? Hugh [email protected] |
02-04-2019, 04:48 PM | #8 | |
Use a set of wedges, -or a bearing splitter. |
02-04-2019, 06:14 PM | #9 |
Bearings are low in cost and might be able to get at local parts store. For cars they were the same up to 48.
https://www.snydersantiqueauto.com/front-wheel-bearings
02-06-2019, 10:49 AM | #10 |
Brent, Set Of Wedges? Bearing splitter ? what is that?
Thanks, Hugh |
02-06-2019, 12:33 PM | #11 |
Bearing splitter or puller.
02-06-2019, 04:54 PM | #12 |
Is the bearing staked on the spindle after the bearing was slid on ? Can you see the stake marks ? If so, I would think a dremel or file would work. Also see if you can drive a chisel behind the bearing to push it forward on the spindle.
If that doesn't work then remove the rollers and cage. An acetylene torch can be used to heat a a red hot spot on the race and take 2 ball peen hammers and whack the race on the hot spot to expand the race. [ the ball of one hammer on the hot spot them whack that hammer with the second one. A grinder can also be used to split the race. |
02-06-2019, 07:39 PM | #13 |
I used a Dremel tool to slit it almost to the spindle. Then hit the slit with chisel and split it enough to slide it off. I then cleaned up axle as Brent recommended.
02-07-2019, 04:23 PM | #14 |
If they used Loctite you may need to use a little heat. Only heat up the bearing race though, do not heat the spindle too much. Loctite will release with heat.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
02-07-2019, 04:35 PM | #15 |
For those of us who haven't experienced this, why would someone peen or stake the inner wheel bearing to the spindle?
02-07-2019, 07:59 PM | #16 | |
A factory issue from Ford when I was a kid were undersized spindles/ loose bearings. Rather than replace those spindles Fords fix was to prick punch the spindle and install the bearing. Didn't seem right to me, but, it was their fix and many were done with no issues. |
11-20-2021, 11:47 AM | #17 | |
Slightly undersized spindles with a loose inner bearing race seems to be the case on my '31, the race for inner bearing turns smoothly on the spindle. A very experienced club member said the spindle and bearings were in good shape, but he recommended peening the spindle at three points around the spindle, then filing it so the race fits tighter and doesn't spin. Seems odd though, is this the correct way to address the issue? If not addressed does this eventually damage the spindle and create wobble in the front? |
11-20-2021, 04:56 PM | #18 | |
11-21-2021, 12:08 PM | #19 | |
11-21-2021, 12:33 PM | #20 |
